don't have an XLE but I have done it on my LE
Originally Posted by Hillingdon
Looked at the 02 pdf shop manual. I did not see where it mentions removing the rear shade. According to what I see there, you remove the seat belt anchors, remove the trim on the parcel tray so that the anchor can go through and then everything seems to pull out from under the glass end of the tray. Only thing I belive it said to do was remove the 3rd brake light first (going off memory there).
looks right, you have to remove the 3rd brake light, or the wire will rip right out of it when you pull up the rear package tray. it's been a while, but i believe you slide the third brake light to the left, then you can pull it up and out. you may need to use quite a bit of force to slide it left.
the package tray just doesn't pull out... there are two clips forward of the speaker grills. you'll have to pull up on the front edge of the package tray until it pops up, then pull it out. this is how i've done it on my LE.
if you cannot see any bolts attaching the rear shade to the trunk, then it is only attached to the package tray. i'd try removing the package tray like I did on my LE.
