JBL System--Can you use an aftermarket amp? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2011, 04:20 PM   #1 (permalink)
View sean55's Photo Gallery
Subject says it all....
Can you replace the OEM amp with an aftermarket?
Thanks
sean55 is offline   Reply With Quote
Old 04-03-2011, 06:23 PM   #2 (permalink)
bump
Old 04-04-2011, 08:22 AM   #3 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
If it's this one, then yes but I suggest to track down appropriate Molex connectors and attach back to the OEM connectors.
There's factory FSM floating around here somewhere. Just make a search.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 04-04-2011, 03:07 PM   #4 (permalink)
Waffler
Hillingdon's Avatar
View Hillingdon's Photo Gallery
Keep in mind the ohm load as well if you are just trying to replace the amp, but keep the factory speakers. Not sure what car you have, but on mine the ohm load for the speakers for the doors was 2.8 or 2.9 and were run together with the dash speakers so that dropped it lower.
If you are looking to use the factory head unit and run aftermarket amps and speakers then you can just run a loc to convert the speaker outputs to RCA and go from there. Lots available.
A glass of Chateu Thames Embankment please.....
Don't fix it if it isn't broken! Muck with it until it is broken and THEN fix it.
Hillingdon is offline   Reply With Quote
Old 05-01-2011, 10:35 AM   #5 (permalink)
View jdhopki's Photo Gallery
I have a failed 86280 0w390 (2007 Camry SLE) and think the 0w391 is a replacement.
What do you suggest as a replacement or a place that sells the OEM version. Thanks
jdhopki is offline   Reply With Quote
Old 05-01-2011, 12:19 PM   #6 (permalink)
View lysaer's Photo Gallery
I recently tried to replace everything but the headunit in my 07 SE, and discovered that the head unit's volume, fade, settings all control the amp's output itself. If you're adding an aftermarket amp you're going to lose that control unless you tap the wires returning to the head unit from the amp, and good luck finding those. I have Luna's tech diagram and it doesn't match mine. :/
lysaer is offline   Reply With Quote
