Another Gen 6 V6 Trans Failure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2011, 09:13 AM   #1 (permalink)
Toyota Parts since 1981
Gameroom cash: $148255
View DOHCammer's Photo Gallery
I bought my 07 SE almost a year ago with 62k on it. I made sure my dealership certified it so I had the extended powertrain warranty. I immediately noticed the infamous 3-4 shift flare and had the newest updates downloaded into the trans ECU. Since then, I occasionally experienced slippage between shifts especially if I had been traveling for awhile. Around town seemed fine, until last week. Trans seemed to be slipping a little on takeoff and noticed some flare in the upper shifts. Check engine light on last Saturday, pulled code P2714 on my Scanguage II. P2714 refers to the line pressure shift solenoid so right away I knew something was up. Erased it and kept driving. By Wendesday morning, CEL was back on (same code) and the trans was slipping so bad in the upper gears I had to nurse it to work in sport mode 3rd gear. The code came about because the clutches was so worn the solenoid could not provide the line pressure necessary to prevent slippage. Needless to say the trans is toast. Adjuster came by on Friday and OK'd the new unit. This could have been a financial disaster if I bought this car with no warranty. The reman trans list for over $3100 and the 7 hours of labor needed for the swap would have put the total cost at over $4000 with tax.
05 Highlander V6 AWD
170K miles young
07 Camry SE V6 SOLD!!
TRD Dual Exhaust & Air Filter
DOHCammer is offline   Reply With Quote
Old 04-03-2011, 10:02 AM   #2 (permalink)
View Shelbrain's Photo Gallery
I too had the same code and issue, albeit mine occurred much earlier at 8,000 miles. (08 Camry) I've had the occasional problem since then, but nothing to extent it was before. Thankfully you had your extended warranty. I purchased my car during a time when Toyota was offering lifetime powertrain warranties on new and certified used vehicles. There is a dealership in my area Wesley Chapel Toyota who continues to offer this - I believe they are the only one in FL authorized to do so. Warranty is not through Toyota but an insurance company and the deductible would be $50 in the event there is a covered repair.
Shelbrain is offline   Reply With Quote
Old 04-04-2011, 02:54 PM   #3 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $150432
View Yazovets's Photo Gallery
That's not too bad actually.
My tranny had to be replaced at just 53,000km (33,000m).
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 04-04-2011, 03:35 PM   #4 (permalink)
Camry SE Noob
View xShoOtin StarSx's Photo Gallery
im scared now. no issues with my 07 yet.
2007 Camry SE V6 w/ Leather and JBL Navi
6000K Low beams & Fogs
xShoOtin StarSx is offline   Reply With Quote
Old 04-09-2011, 05:47 PM   #5 (permalink)
View anagram4m's Photo Gallery
Question Model U140E - V6 Transmission slipping
I too am a victim of V6 Transmission. I have another post on this forum that I am updating. I started having problems at 95K miles with Reverse slipping under a load (such as backing out a parking space on a hill). Now at 119K miles I have slipping going from 3rd to 4th gears. After speaking with 2 different local shops, they say that this Model U140E trans has a valve body that wears out the clutch for Reverse and high gears. No codes , check engine or OD lights log errors. Even though with little searching and this model has this problem way more than other Toyota models, Toyota will not acknowledge this as a problem to recall.
Has anyone got their dealer to repair or replace this model trans out of warranty
REVISED: I have a 2002 V6
anagram4m is offline   Reply With Quote
Old 04-10-2011, 07:20 AM   #6 (permalink)
MJZ
Bulletime
MJZ's Avatar
Gameroom cash: $438105
View MJZ's Photo Gallery
I'm getting hard downshifts from 6-5-4-3 but normal driving is fine. Cold start is still very harsh shifting all around.
I have a 70K Mile warranty so I'm hoping it goes before then.
MJZ is offline   Reply With Quote
Old 04-10-2011, 12:41 PM   #7 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
The gen 6 V6 uses the U660E trans
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
