Oil Filter Size - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-04-2011, 10:55 AM   #1 (permalink)
View knfenimore's Photo Gallery
Oil Filter Size
I have an 09 Camry V6 SE with 35k miles on it. I change my oil every 5k miles. I use Mobil1 5W30 and Purolator filters. I have noticed that the filters are collapsed in the middle when I remove them. This is a sign of excessive contamination in the filter, reducing flow. I was wondering if anyone else is having this issue. Also, I was told the 2011 goes 10k miles before needing an oil change. Does the 11/12 use a different/larger oil filter housing and oil filter. If so, would that housing fit the 09 Camry?
Thanks
knfenimore is offline   Reply With Quote
Old 04-04-2011, 11:47 AM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
I have use Toyota and Fram. They appear to be identical when new and when used. I've never seen wheat you described. When in doubt use the OEM filer--they cost essentially the same. Always ask for a discount at the parts counter. As for design changes, I am not aware of anything happening there, and I would never consider letting the oil change go for 10k miles, synthetic or not. Check the cost of a short block and then the cost of oil changes every 5k miles. Do the math!
gdanaher is offline   Reply With Quote
The Following User Says Thank You to gdanaher For This Useful Post:
Donald E. George (04-04-2011)
Old 04-04-2011, 11:58 AM   #3 (permalink)
Filter
I was not wanting to go more miles. I just wanted more filter material.
Old 04-04-2011, 12:15 PM   #4 (permalink)
molson.david's Avatar
Gameroom cash: $295253
View molson.david's Photo Gallery
change your filters more often, or use extended life filters.
I doubt you can use "bigger" filter. even if it will fit, filter mite have differend specs.
I'm using Fram XG for synthetic oil. running Valvoline, intervals 8-9K miles.
had no problems on my previous camry, used same oil and fram filters for 100+K.
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is online now   Reply With Quote
Old 04-04-2011, 12:52 PM   #5 (permalink)
View jbrnigan's Photo Gallery
see link for an explanation of your colapsed oil filter - so much for the forum experts
http://www.machinerylubrication.com/...ne-oil-filters
2011 SE V-6, Classic Silver, Leather, Moonroof, JBL
30% Tint, K&N, CPP Strut Brace, De-badged, Pin striped
2009 Corolla S, Classic Silver, 30% Tint, K&N,
jbrnigan is offline   Reply With Quote
Old 04-04-2011, 01:26 PM   #6 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $477210
iTrader Score: 12 reviews
View bandit's Photo Gallery
No one claimed to be experts. Everyone here is a normal user like yourself regardless of status. What people post is based on self knowledge, opinion or from first hand experience. Not all information may be correct. Just like doing a Google search...not everything is correct.
CarDomain
Old 04-04-2011, 01:29 PM   #7 (permalink)
Filter
Thanks for the info. I change it at the recommended service interval. I guess it could be the oil pump pressure relief. The filter housing can only take one size filter and they are only the filter element. I guess I will try changing it sooner first and see how that does. I was hoping that the new Camry had a larger filter that would keep me from changing it so quickly.
Old 04-04-2011, 01:57 PM   #8 (permalink)
Mr. Moderator, touche - the consensus replys prior to my post were to change the filter more frequently, and knfenimore cited that he already changed his filters every 5K. I only suggested that his problem has a different solution than more frequent filter changes. Yep, you're right, they weren't experts and all Google searches aren't correct, but this one was.
Old 04-04-2011, 05:29 PM   #9 (permalink)
View motorking's Photo Gallery
Thanks
Hi,
I am the tech manager at Fram Filters. You are correct in your assesment that the filter is collapsing due to contamination. The link in this thread to the FMC article on collapsed center tubes is a very clear explanation of this. We make a more heavy duty filter cartridge for your car, the Fram TG9972. Here is a link to the description-http://www.framcatalog.com/PartDetailWindow.aspx?b=F&pn=TG9972. While our standard CH9972 filter is rated for 5k on your vehicle, the TG9972 has the capacity for 7500 mile oil changes. See more at Fram.com/proof
motorking is offline   Reply With Quote
The Following User Says Thank You to motorking For This Useful Post:
workerant (04-04-2011)
Old 04-04-2011, 09:28 PM   #10 (permalink)
View '11 Land Cruiser's Photo Gallery
The Purolator that fits the 4 cyl. has a plastic "cup" around each end of the filter.
I haven't looked at the V6 version at the auto parts to see if they are built the same way.
I haven't installed one of the Purolators yet. I've just used the factory filters and a Fram or two.
There is always Wix/NAPA or Baldwin/Hastings filters to consider.
'11 Land Cruiser is offline   Reply With Quote
Old 04-05-2011, 08:10 AM   #11 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
That happened to me with a prolator at 3000 miles. Been using Toyota filters ever since and have had 0 collapsing when I change it. Use Toyota filters. Fram is garbage. As well as prolator when it comes to cartridge filters.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 04-05-2011, 01:01 PM   #12 (permalink)
I'm glad that I am not the only one that had the collapsed Purolators. Thanks for the replies!
Old 04-05-2011, 04:40 PM   #13 (permalink)
must.resist.modding
bandit's Avatar
Purchase OEM oil filters on eBay and you wont ever have to worry again. I paid $38 (or $42) including shipping for 10. Thats $3.80-4.20 each. Here in NY if you buy FRAM, Purlator or some other brand, its over $5.
CarDomain
Old 04-05-2011, 08:59 PM   #14 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
