ABS wiring replacement 2002 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-04-2011, 01:14 PM   #1 (permalink)
View tjm4591's Photo Gallery
2002 Camry 4cyl. 166,000 miles. Brake light and ABS light comes on at start up and stays on. Took it to a non-dealer repair shop. They told me wiring to LR ABS sensor is bad. And...need to replace the rear hub to replace the sensor and wiring for about $760. Makes ABS non-functional but regular braking is ok. I figured with age of car I'll try it myself as I've replaced brakes, claipers etc. on other cars before. So I search this fine forum. Replacing a rear hub seems pretty straight forward. But from what I can tell, I should not need to replace the hub to replace the wiring. Am I right?
Is it possible to pull the wiring harnes from the sensor to the ABS module and test/replace just that?
Or can you only get sensor and wiring as one piece?
Would ABS still pulse the other 3 wheels leaving the LR to lock up? just want to anticipate this if it's expected.
(additional info got struts replaced 2 years ago)
thanks for any info.
tjm4591 is offline   Reply With Quote
Old 04-04-2011, 05:44 PM   #2 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
I think you have to remove the axle hub assembly from the carrier after disconecting the sensor wiring. From what I can tell,the sensor is a friction fit inside the hub and requires somekind of a puller. Replacing the wiring looks like a big job considering you have a ten year old car. Regards.
Donald E. George is offline   Reply With Quote
