Transmission adjustments? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2011, 07:19 PM   #1 (permalink)
View jermag24's Photo Gallery
Is there any way to stop my 2004 Camry XLE from shifting at such low RPM's? I'm forced to manually shift if I want any power from the engine. I know older generation had a kick-down cable they could adjust to make the transmission hold gears longer.
What are my options?
jermag24 is offline   Reply With Quote
Old 04-09-2011, 10:16 PM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
Nope. It is what it is. You have a somewhat underpowered engine pulling a somewhat heavy car. It needs more engine.
gdanaher is offline   Reply With Quote
Old 04-10-2011, 10:20 AM   #3 (permalink)
Thanks for the reply. When I shift manually, and actually let the engine build some rev's it drives fine. The problem isn't too little power, it that this transmission shifts to the next gear way before the engine gets into it's power. It will shift into 4th gear before I've hit 40 mph. Any valve body kits, tuners, etc to change the shift points?
Old 04-10-2011, 02:00 PM   #4 (permalink)
Somewhat a Lurker
Gameroom cash: $311669
View Agent556's Photo Gallery
press the gas pedal harder, really. if you floor it, the car should shift at redline. if you press the gas pedal harder than whatever youre doing right now, it should shift a little later.
2005 Camry SE V6
http://www.toyotanation.com/forum/sh...d.php?t=343592
Agent556 is offline   Reply With Quote
