2008 Camry starting problem. Not battery, starter, alternator, what else - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2011, 09:50 PM   #1 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
I have a 2008 camry LE 4 cyl.
Been having issues starting and it is a hit or miss thing. Just rode back in a AAA truck
The battery is new and I took it to autozone this morning and they said, Batt, alternator and starter is good after they hooked up their hand help diagnosis machine.
Symptoms: Driving it and if you run into the gas station, it will not start up.
The engine will turn, and people tried to help is saying fuel issue... From fuel pump, fuel line to fuel filter.
I do not want to get ahead of myself.
Any idea?
If it is the fuel system, I think tacking the fuel filter makes most sense. Anybody done it here with instructions?
I have done it for a 93 and 2000 camry.
TIA
skewe is offline   Reply With Quote
Old 04-09-2011, 10:07 PM   #2 (permalink)
View Judy H's Photo Gallery
I would change the fuel filter for sure.
Should be it.
~Judy in MI~ Should be easy enough.
Judy H is offline   Reply With Quote
Old 04-09-2011, 10:09 PM   #3 (permalink)
It wouldn`t be the fuel pump, unless the tube is partially plugged, only then would it
be a hit & miss. If bad fuel pump, I don`t think it would start at all~
~Judy in MI~
Old 04-09-2011, 10:09 PM   #4 (permalink)
heartdisease's Avatar
Gameroom cash: $109570
View heartdisease's Photo Gallery
My wifes 2001 Malibu did the same thing to me at a gas station. I switched out a couple relay's under the hood (same exact ones) and it started. It turned out to be a bad fuel pump relay, like 10 bucks. I hope that is what it is for ya
heartdisease is offline   Reply With Quote
Old 04-09-2011, 10:13 PM   #5 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
The fuel pump and filter are inside the tank and requires surgery. If it runs perfectly fine when cold and when on the highway, I would doubt it is the pump. You need to check the fuel pressure though and that means a trip to your trusted Toyota mechanic or dealer.
gdanaher is offline   Reply With Quote
Old 04-09-2011, 11:06 PM   #6 (permalink)
It may be the fuel pump relay, but that would mean maybe only won`t start when it gets hot? (the relay). Not sure, but have to know >> does it do it only after driving so long, or short trips? I do know a little about relays, and if they get hot, they will
not work and once cooled down, will work again. But still feel it is fuel filter. Or maybe even the fuel pump, but like I said, it would have to be partically plugged or
no good. I would think if it were the fuel pump it wouldn`t start at all~~~
~Judy in MI~ Hope this helps?
Old 04-10-2011, 08:40 AM   #7 (permalink)
View dolfan's Photo Gallery
Try removing the gas cap then start.We had some vent tube issues in the past.
dolfan is offline   Reply With Quote
Old 04-10-2011, 10:16 AM   #8 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
I can guaranteed you that it's not the fuel filter. I am telling you this now, don't mess with the filter, you're just wasting time.
That's not the way to diagnose your car. Im assuming theres no check engine light and the problem isn't intermittent.
1. check to see if immobilizer transceiver or key isn't a problem.
2. check the fuel pump relay to see if it still work properly.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 04-10-2011, 02:18 PM   #9 (permalink)
skewe's Avatar
I will check the fuel pump relay.
It happens on short n long trips. I m bait puzzled by this and I am not sure if I want to dig into the gas tank for the fuel filter.
And the bad thing is it does not happen everyday.
1, will check the relays
2, will check the fob key and even try the valet key
Old 04-10-2011, 03:17 PM   #10 (permalink)
View 89molavi's Photo Gallery
Check the Battery terminals and also the ground, make sure everything is tight. Also next time this happens go to a mechanic (unless still under warranty-then the dealer). I have been told many things by pepboys, not always true though. The quality of the people working there could be all over the map.
89molavi is offline   Reply With Quote
Old 04-10-2011, 07:21 PM   #11 (permalink)
View jbrnigan's Photo Gallery
if you're not getting a CEL, save yourself a lot of time, agravation and money and see a qualified technition. another thought, get a code reader and hook it to the OBD port on the car. sometimes OBD codes are stored and won't turn on the CEL if they correct or reset themselves when the ignition is recycled
2011 SE V-6, Classic Silver, Leather, Moonroof, JBL
30% Tint, K&N, CPP Strut Brace, De-badged, Pin striped
2009 Corolla S, Classic Silver, 30% Tint, K&N,
jbrnigan is offline   Reply With Quote
Old 04-11-2011, 03:01 AM   #12 (permalink)
View hbbadb0y's Photo Gallery
I bet its a camshaft sensor or crankshaft sensor.
hbbadb0y is offline   Reply With Quote
Old 04-11-2011, 04:27 PM   #13 (permalink)
that would throw a big CEL
