Just got 2004 Camry with 100K on it. what maintenance is needed? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2011, 01:24 PM   #1 (permalink)
View bored7one4's Photo Gallery
Just got a used camry with 100k miles on it. wanted to know the following on what needs to be done at 100k and what type of filter and oils to use?
Engine oil - ?
Transmission oil - ?
Filter - ?
100k mile maintenance - ?
thanks
bored7one4 is offline   Reply With Quote
Old 04-11-2011, 03:42 PM   #2 (permalink)
what type of spark plugs and coolant to use also?
Old 04-11-2011, 05:29 PM   #3 (permalink)
Banned
Gameroom cash: $216100
View BlackG5's Photo Gallery
1) Serpentine belt if its never been replaced
2) Change the oil, you decide synthetic or regular depending on your driving
3) PCV valve- its $5
4) use oem toyota coolant, if you're handy and do your own oil, you can drain and fill coolant even easier.
5) cant hurt to seafoam it- there are plenty of vids on how-to youtube..
6) plugs- use oem iridiums- they're like $9-10 a piece at autozone, easy to change
7) gas, although it really won't use much
I've been more than happy with mine, now at 170k on my 04.. keep up with oil and be easy on her, she'll last.
BlackG5 is offline   Reply With Quote
Old 04-11-2011, 05:38 PM   #4 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
Engine oil is 5W-30 API. It's shown on the oil filler cap. Coolant is Toyota Long Life pink stuff ,but I use Zerex Asian Car coolant because I refuse to pay Toyota $28.00 a gallon for their pink stuff. Get it from NAPA. Timing belt is replaced at 9 years or 90,000 miles so you are overdue if it hasn't been changed. The owner's maual and maintenance schedule that came with the car shows everything that needs to be done. You did get those with the car didn't you? I personally would never purchase a car that didn't have the maintenance schedule and owner's manual.
Donald E. George is offline   Reply With Quote
Old 04-11-2011, 07:06 PM   #5 (permalink)
Gameroom cash: $137274
View johnfrisco's Photo Gallery
Only the 6 Cylinder engines use a timing belt. If you have a 4 Cylinder you have a timing chain and they usually last forever.
johnfrisco is offline   Reply With Quote
The Following User Says Thank You to johnfrisco For This Useful Post:
Donald E. George (04-12-2011)
Old 04-12-2011, 04:33 PM   #6 (permalink)
JohnFrisco is right. I overlooked that. Toyota says the "allowable stretch" for the chain used by the I4 is a little over 4.5". Enjoy your 04 whatever engine you have.
Old 04-12-2011, 05:42 PM   #7 (permalink)
thanks for all the info guy!.
Ill change all the fluids out this weekend. I was thinking about changing ATF with Redline D4.
Old 04-12-2011, 08:09 PM   #8 (permalink)
I just was just told my camry my wife bought was an 2003. is that still a timing chain or timing belt?
Old 04-12-2011, 08:27 PM   #9 (permalink)
4 Cylinder = Chain
6 Cylinder = Belt
Old 04-12-2011, 08:44 PM   #10 (permalink)
Joined the dark side. :D
Gameroom cash: $656191
View workerant's Photo Gallery
Originally Posted by johnfrisco View Post
4 Cylinder = Chain
6 Cylinder = Belt
8 = rubber bands
windshield wiper
tire rotation, might need new tires too double check on the thread and year of the tire (do a search for how to read this from the tires)
workerant is online now   Reply With Quote
Old 04-12-2011, 09:32 PM   #11 (permalink)
Avy
Gameroom cash: $819455
View pmesfun's Photo Gallery
Power Steering fluid(actually Dexron ATF) and brake fluid flush. Those probably look pretty nasty at that mileage.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 04-14-2011, 03:43 PM   #12 (permalink)
When doing a drain and fill on ATF. how many qts should i put back in?
Old 04-14-2011, 04:52 PM   #13 (permalink)
I have a 2004 V6 with the five speed AT. I drained out 4.5 qts. when the fluid was hot. After that, I put the same amount in via the dip stick tube,ran the car,[I spaced this out over a period of days] and repeated this procedure three more times. The fluid then looked as good as what was in a new container of T-IV [Mobil 3309] fluid. You will need some new 18mm drain plug gaskets. The drain plug torques to 36 ft.lbs. This can be a real pain in the a double ss if you don't have the right equipment or access to getting rid of the old fluid. I give mine to a guy who burns it in his barn heater.I'm getting older and crawling under cars is getting to be a problem, so I will soon be having my oil changes done. Regards
Old 04-14-2011, 06:14 PM   #14 (permalink)
Dose anyone know how many qt for V4 camry?
Old 04-14-2011, 06:35 PM   #15 (permalink)
no such thing. check your owner manual.
