Amp installation kit recommendations. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2011, 06:59 PM   #1 (permalink)
View BlissfulAgony's Photo Gallery
Hi I was wondering what kind of amp installation kits you guys recommend using. I have a Rokford Fosgate R500-1 amp and its going to be installed on a 2007 Camry.
BlissfulAgony is offline   Reply With Quote
Old 04-12-2011, 07:10 PM   #2 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $530410
View BlackCam09's Photo Gallery
what gauge wire does it recommend on the amp?? i'm assuming prob 4gauge right? i'd go with kicker personally, but any amp kit will do just fine, just make sure it comes with everything you need. Knukonceptz.com has good amp kits too, ive bought form them a couple of times.
http://www.knukonceptz.com/productMa...llation%20Kits
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is offline   Reply With Quote
Old 04-12-2011, 07:23 PM   #3 (permalink)
it can go up to 4 gauge, I was thinking about the Rockford Fosgate installation kit but it says the powerwire is only 17 ft. Do you think that would be long enough?
Old 04-12-2011, 07:36 PM   #4 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Yeah its up to you, most kit comes with 17ft-20ft power gauge wire. I think my kicker 0gauge kit came with 20ft. That should be long enough, do you have a i4 or v6? I know the v6 is a little bit more space confined and not much room to work with and run the wire compared to the i4.
Old 04-12-2011, 07:38 PM   #5 (permalink)
I have the V6
Old 04-12-2011, 07:56 PM   #6 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
ah i see, its going to be less space for you to work with then, i have a i4 so there was plenty of space to work with and run the wires, i ran it through the grommet in the firewall where the stock wires from the car was running out to the engine bay. I don't know if the v6 is the same or not though.
Old 07-12-2011, 11:01 AM   #7 (permalink)
View boatbuilder's Photo Gallery
I am searching for a firewall location on my 2011 LE v6. Does anyone have a pic of where to run a 4 ga amp power wire through on 11' LE v6? Please advise. I've searched the forums extensively and have not been able to locate anything.
boatbuilder is offline   Reply With Quote
Old 07-12-2011, 11:32 AM   #8 (permalink)
270hp = Happy Foot
Gameroom cash: $396245
View aznlunatic206's Photo Gallery
I go through a big rubber boot above the steering column, if you open your hood and look at the right side of the firewall you see a big black rubber boot that has a a bundle of wire going into the engine bay, that's where i routed my 4gauge power wire through. let me know if you need a pic.
2011 Camry SE V6 Fully Loaded w/o Navi
V-HIDS 5000k HID Kit Low Beam, 3000k Nokya Fogs
20% Aegis Tint, 50% Front Windshield
Tein Solara Springs on KYB GR2's
aznlunatic206 is offline   Reply With Quote
Old 07-12-2011, 12:54 PM   #9 (permalink)
Thank you! I'll take a look in that location tonight.
