2007 Camry SE Recirculate issue. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2011, 10:57 AM   #1 (permalink)
View igbeserk's Photo Gallery
I've tried doing a search on this to see if it was already addressed but all i could seem to find was people annoyed about how short the recirculation time is.
Basically I can't get the recirculation to come on i press the button and it doesn't light up. I of course turn on the ac or fan. Tried under hot or cold and even the middle. It just recently happened. I figured it's mainly do to the fact that I added a short air intake with a K&N filter and i guess the system isn't registering it right? It's not the one recommended for the car but it works. The intake adapter for the MAF sensor doesn't fit because it was meant for a 2004 corolla. so me and my friend just taped it down trying to insure that no extra air comes in, but it's air so it's bound to get in.
So is it the air intake that's causing this? or it might be something else? if so i'll put everything back to stock until i can get something better.
i'll post a pic later if that's needed.
igbeserk is offline   Reply With Quote
Old 04-20-2011, 11:10 AM   #2 (permalink)
Gameroom cash: $106850
View JBandit03's Photo Gallery
Dont have it set to the defroster do ya? If it is on defroster, it wont turn on.
I know I had the opposite problem with mine being set on "Max A/C" where recirc stays on. I was used to the others without the Max A/C setting and having to manually turn recirc on.
JBandit03 is offline   Reply With Quote
Old 04-20-2011, 11:27 AM   #3 (permalink)
Joined the dark side. :D
Gameroom cash: $656191
View workerant's Photo Gallery
^ I used to hate that. With A/C turn all the way it will go into defrost, recirculate air get switch to outside air, and the RPM also jump up due to the A/C turning ON. I didn't want A/C, I just didn't want the heat to be ON.
I did think something was wrong too.
workerant is online now   Reply With Quote
Old 04-20-2011, 11:35 AM   #4 (permalink)
nope did not have defroster on. when the light on the recirculate wasn't coming on i thought maybe i messed something up. so i tried max ac and i tried defroster those came on fine.
Old 04-21-2011, 08:49 AM   #5 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
the LED for the light could be burnt out..... try this: turn the fan on high, selector on face vents, and temp on cool..... run for a few secs then press the recirc button.... if u listen to the dash on the passenger side u shud notice the airflow sounds a bit louder if its working
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
Old 04-21-2011, 11:26 AM   #6 (permalink)
Sorry guys was an idiotic mistake. had it set to the window defroster as the option. then again. the little bulb on the dial for the defroster went out but still yea dumb on my part works fine when it's actually set to fan
