Hi guys, please pardon this needy first post.
I've been searching for two days on here, but I can't find what I need.
A few days ago I found a clearly designated wiring diagram for the factory JBL stereo and amp, but I can't find it anymore. I spent yesterday replacing all the factory speakers and need to wire up the amps now, and I want to wiretap on the wires going from the radio to the JBl amp. So I need to know which plug into the amp is what, and what wires are what. There are a lot more than your average power/ground/remote/left/right.
And now that's done, here are some details on what I've done so far:
Replaced the front dash tweeters with SoundStorm Labs 3.5" 2-way speakers (
GS235)
Replaced the door and rear 6x9's with SoundStorm labs 6x9 3-way speakers (
GS369)
Notes on the speakers: Installing the dash speakers required some minor cutting of the dash where the old speakers were, and this also required removing the metal slip-on screwholes the originals were mounted in. Used some foam tape to mount and reduce vibration as well. But the trim panels fit back in perfectly afterwards.
The rear deck speakers required some mounting adapters but with some trial and error, fit fine (plenty of clearance on the tension bars for the trunk lid).
For the door speakers, I pulled the factory speakers free of the mounting frame (easy with a utility knife to cut through the mounting tape), trimmed the inside edge down so the new speakers would fit in, screwed them down and they went back in the door just like the factory, with no clearance issues on the windows!
I'm wiring up an SSL equalizer (high level inputs where I'm tapping in as mentioned before, and 3 RCA outputs for front, rear, and sub). An MB Quart Onyx4.125 amp powers the main speakers, and an SSL Evolution EV1500M powers a 12" Pioneer Champion DVC sub.
Now if I can just find that wiring diagram!
