2009 Camry XLE - popping noises from front end - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2011, 11:45 PM   #1 (permalink)
View MDFLAW's Photo Gallery
I have a 2009 Toyota Camry XLE. I keep hearing a popping noise in the right front of the vehicle when I release my foot off the brake after being at a dead stop and also when turning at a slow speed. I have had the brakes checked and everything looks fine. I also had a front end alignment and nothing was noted as being out of the ordinary. I am wondering has anyone else experienced this same problem.
MDFLAW is offline   Reply With Quote
Old 04-26-2011, 08:36 AM   #2 (permalink)
Is this real life?
Joe Dirt's Avatar
Gameroom cash: $108950
View Joe Dirt's Photo Gallery
I had that exact same issue after getting my car back from the body shop- replaced nothing that would cause noise. It was a single 'pop' when it did it. I drove it last fall, it made that noise for about 4-5 weeks, and I put it into storage for the winter. When I pulled it out this spring, the noise was gone. No idea what it was, or what fixed it. That probably doesn't help at all, but...
'07 Camry XLE I4
Joe Dirt is offline   Reply With Quote
Old 04-26-2011, 08:52 AM   #3 (permalink)
gonzo08452's Avatar
View gonzo08452's Photo Gallery
my sister had this exact thing happen on her 07 Altima V6. Turned out to be the front motor mount. It could also be the front axle. If so, it should be under the powertrain warranty. Good luck.
gonzo08452 is offline   Reply With Quote
Old 06-03-2011, 05:40 PM   #4 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
it's very likely that it is your cv axle, especially if it does it more when turning, especially when turning hard. sometimes it is even more pronounced when you turn hard in reverse.
nitronate33 is offline   Reply With Quote
Old 06-03-2011, 05:43 PM   #5 (permalink)
Tech1984's Avatar
Gameroom cash: $254450
View Tech1984's Photo Gallery
Check to see if the tie rod nuts are tight. I've seen a few after alignments loose as a goose.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is online now   Reply With Quote
Old 07-08-2011, 10:06 AM   #6 (permalink)
keep your boost up
cp44's Avatar
View cp44's Photo Gallery
I have the exact same problem in my 07 SE V6. any updates from the OP on the resolution?
:\Documents and Settings\aaron.wu\Desktop\LIGHTS.jpg
A wise man once said "If ignorance is bliss and patience is a virture, you'll have a good life if your dumb enough to wait"
cp44 is offline   Reply With Quote
