try this
This is how i fixed the dead cigarette lighter in my old 1988 nissan pickup. I simply bypassed the dead socket and its wiring.
i wanted a hot connection all the time because i wanted to use a solar battery charger. I did not want to spend hours or days rooting around under the dash and this was an easy and safe solution.
just go to the fuse box and find a connection that is hot all the time (your Volt ohmeter can tell you whats a good one - pick a connection that uses the same amps as the cigarrete lighter). and use the fuse tap (that's the proper name for them).
then you can just run your wires under the dash and to a new cigarrete lighter connection. It took me all of 45 minutes and no controtionist work under the dash either.
Be sure and splice in a fuse holder and fuse in the hot wire, same amps as the circuit of course.
