Any DIY for 2003 camry tranmission flush? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2011, 03:00 PM   #1 (permalink)
View bored7one4's Photo Gallery
I have search but only see DIY for 3rd and 4th gen write up. Do I have to use a 10mm Allen (Hex) Key Wrench to drain the pan?
thanks
bored7one4 is offline   Reply With Quote
Old 04-27-2011, 03:12 PM   #2 (permalink)
View Mike Murrell's Photo Gallery
What size engine? Might help those who've done that year.
Mike Murrell is offline   Reply With Quote
Old 04-27-2011, 07:51 PM   #3 (permalink)
I have a 4 cylinder 2003 camry
Old 04-28-2011, 05:23 PM   #4 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
My 04 takes a 10mm hex bit to remove the AT drain plug.You can purchase a 1/2" drive, 10mm hex bit socket and use a breaker bar.You will need a 18mm replacement gasket for the plug. The plug torques to 36 ft lbs. You will only be able to drain out about 4 quarts of fluid because most of the fluid is in the torque converter which does not have a drain plug. Unless you have the equipment to do this maintenance,have a shop do it. A gallon of hot ATF can make a mess fast.
Donald E. George is offline   Reply With Quote
Old 04-29-2011, 12:34 PM   #5 (permalink)
The transverse-mounted 4 bangers I've owned drain so much as pointed out above.
That said- I've put over 300K on 2 by draining only what comes out(usually half) -then refilling with that amt.
Some call it rotational draining.
Old 04-29-2011, 02:31 PM   #6 (permalink)
If you drain and refill three or four times with a little driving or running time between each drain,you will be doing what the flush machines do. I put 18 quarts through my AT and the fluid looks as good as new. Regards.
