I messed up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-28-2011, 08:40 PM   #1 (permalink)
View ShadowMedic's Photo Gallery
I messed up
So I removed the plastic cover on my 2005 Camry, I cleaned it up because I spilled oil all over the thing. I put the bolts back on and yep the one on the right snapped. I also lost the rubber thing up in the left hand corner.
First question how do I go about replacing this bolt I snapped off?
Second question is what do I ask for to replace the rubber part that went missing?
ShadowMedic is offline   Reply With Quote
Old 04-28-2011, 08:43 PM   #2 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1077958
iTrader Score: 7 reviews
Cover of what? the engine cover?
2002 Camry SE V6 "Snow White"
Old 04-28-2011, 08:54 PM   #3 (permalink)
Yeah the engine cover... I swore I wrote that in there
Old 04-28-2011, 08:59 PM   #4 (permalink)
Gameroom cash: $169021
View Dave-o's Photo Gallery
plastic cover....the whole car's plastic...the engine cover? you somehow overtorqued the right nut? left hand corner piece?!?!
Dave-o is online now   Reply With Quote
Old 04-28-2011, 09:03 PM   #5 (permalink)
Yeah the engine covering made out of plastic, and yes somehow I managed to over torque the nut, funny thing was I barely tightened it and it snapped... I broke it though no doubt...
Old 04-28-2011, 09:37 PM   #6 (permalink)
pics?
Old 04-28-2011, 11:24 PM   #7 (permalink)
My camera wouldn't work so I used someone's photos and just circled what I was talking about.
Snapped the bolt on the right...I am missing the rubber piece that covers the other bolt on the upper left.
The bolt is still protruding.
Old 04-28-2011, 11:54 PM   #8 (permalink)
Alright, the rubber cover you don't really need to worry about...
Is the actual engine cover loose? Shut the hood and see if it vibrates when you drive... one bolt should be fine... the cover is basically just there for looks anyway.
Old 04-28-2011, 11:58 PM   #9 (permalink)
Oh yeah she vibrates something fierce
Old 04-29-2011, 02:58 PM   #10 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
Use channellocks to remove the broken off stud. Toyota should be able to supply a replacement. Use a double nut to install the new threaded stud. An alternative would be to try and find a long enough metric bolt and cut the hex head off. Regards.
Donald E. George is offline   Reply With Quote
Old 04-30-2011, 08:39 AM   #11 (permalink)
gator1939's Avatar
Gameroom cash: $245335
View gator1939's Photo Gallery
Since the body of the bolt is still protruding through the cover, could you not use a washer and nut to tighten the cover down? It won't look as pretty but it would be functional and keep the cover from vibrating; and be a faster and cheaper fix.
gator1939
2B1ASK1
gator1939 is offline   Reply With Quote
Old 04-30-2011, 08:51 AM   #12 (permalink)
^ I think it snapped right off, he was just using those pics as an example to show us.
Old 04-30-2011, 09:08 AM   #13 (permalink)
gator1939's Avatar
I was just going by when he said:
QUOTE
The bolt is still protruding." UNQUOTE
If the bolt is still protruding, then he can use a nut.
gator1939
2B1ASK1
