2003 camry sportivo multi information display - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2011, 04:08 PM   #1 (permalink)
View springer111's Photo Gallery
Australia 2003 camry sportivo multi information display
hi guys,the mid has gone blank,no light,no numbers(time,cruse control settings )just a black screen.if i press and hold the mode button i hear a ping but nothing happens.does the mid have its own fuse or does it work of another system,cant seem to be able to locate fuse on fuse panel under steering column.can the mid be reset,if its not the fuse what other areas should i be looking at, any help would be appreciated.cheers springer111
springer111 is offline   Reply With Quote
Old 08-05-2011, 12:00 AM   #2 (permalink)
View fleasss's Photo Gallery
Did you find a solution to this issue? Mine has done the same thing. I have checked all fuses and connections, so I think the unit itself may have decided to sh!t itself.
fleasss is offline   Reply With Quote
Old 08-05-2011, 02:58 AM   #3 (permalink)
2003 mid failure
about 6 weeks after i posted the thread the mid started to work again and is still working. have not got a clue to why it stopped working,maybe a loose or dry connection?
