Power window issues
I've got a blinker...
The driver's door window switch is blinking, which I just noticed on the way home from up north this past weekend. 2 blinks, pause, 2 blinks...
I noticed this morning that the auto down did not work on the driver's door. If I hold the button(s) the windows work on all of the doors.
I did find this TSB referenced:
Copied from TSB PD002-05
NOTE:
Anytime the battery terminal has been disconnected, please initialize the driver’s door
power window and front passenger’s door power window after reconnecting the
battery terminal.
With ignition switch in the “ON” position, do the following:
1. Push down and hold the driver’s door power window switch to completely open
the window.
2. Pull and hold up the driver’s door power window switch until the window closes.
Continue holding the switch for approximately one second until the switch changes
from blinking to a constant illumination.
3. Check for proper operation of the “one–touch open and close” function by fully
pushing the switch briefly to the “DOWN” and “UP” positions.
At this time the power window switch for the passenger’s door window should
be blinking.
4. Push down and hold the passenger’s door power window switch to completely open
the window.
5. Pull and hold up the passenger’s door power window switch until the window closes.
6. Check for proper operation of the “one–touch open and close” function by fully
I followed the procedure, and the auto down works again. But- how did this happen? I never had the battery out or unhooked, how did they reset?
'07 Camry XLE I4
