Camber Kits? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2011, 06:16 PM   #1 (permalink)
WWDDD?
AKM83's Avatar
Gameroom cash: $191650
View AKM83's Photo Gallery
Gen6 Camber Kits?
Where can I buy a camber kit for Gen6?
I checked online and all that seems to come up are camber kit bolts.
Do we even need a camber kit if we go to -2?
AKM83 is offline   Reply With Quote
Old 05-08-2011, 09:30 PM   #2 (permalink)
I got a kangaroo as a pet
private_number's Avatar
Gameroom cash: $343322
View private_number's Photo Gallery
As far as i know they dont. However, what coils are you running?
2007 I4 CAMRY LE, My ride ==> CLICK
Official gen 6 camry hellaflush picture only thread ==> CLICK
private_number is online now   Reply With Quote
The Following User Says Thank You to private_number For This Useful Post:
AKM83 (05-08-2011)
Old 05-08-2011, 09:44 PM   #3 (permalink)
WWDDD?
AKM83's Avatar
Ah well that explains it.
I'm still deciding which set would be best with my 19x9.5 +30 F/R...BCRacing, D2 or KSports are on the list.
I think you have the D2 right? How do they ride--comfortable or harsh? Would you recommend them?
Old 05-08-2011, 10:07 PM   #4 (permalink)
How i look at it bro is that all the coils mentioned above are in the same category. They all fall under the "cheap but good list"
All of which will suffice if all your after is height adjustment. Your not worried about racing nor drifting so they would last. As for the ride, d2s are known to be stiff even at the softest setting. Which for me, is good. ahha
AKM83 (05-08-2011)
Old 05-08-2011, 11:10 PM   #5 (permalink)
WWDDD?
AKM83's Avatar
I see, do you rub with your current set up?
Old 05-09-2011, 01:13 AM   #6 (permalink)
-Kenny-
Guest
Posts: n/a
View -Kenny-'s Photo Gallery
u can go -2 on yur stock bolts
The Following User Says Thank You to For This Useful Post:
AKM83 (05-09-2011)
Old 05-09-2011, 08:15 AM   #7 (permalink)
With a full tank and no rear passengers i rub on major dips. But mind you, thats after a roll and pull and hammering of annoying folds that meet between the fender and the rear bumper.
With passengers, that is a different story. Ive already eaten away my rim protector (not that it had any use)
This is on 6kg/mm spring rate though. Might go to 10kg spring rate in the future.
Received my d2 replacement today. FIY, the quality and build looks much better than the build 2 years ago
yep. maxed out stock bolts and camber plates in the rear and i got -2.8. So i guess if you tried you could get -3 exact
AKM83 (05-09-2011)
Old 05-09-2011, 10:07 AM   #8 (permalink)
-Kenny-
Guest
Posts: n/a
^^^ with mine max stock and plate i got more than -3
Old 05-09-2011, 10:04 PM   #9 (permalink)
WWDDD?
AKM83's Avatar
Thanks for the input guys!
Well, I just ordered the D2 coilovers (got a good deal locally for $835 total) and can't wait until Saturday to install them...I think they're listed at 8.7kgs/5.1kgs. Hoping I won't rub too bad since I'm not on wide-ass SSRs like someone we know...hehe
How low can you go on these? Do you recommend a setting for daily?
Old 05-09-2011, 10:42 PM   #10 (permalink)
haha you should be fine. what are your wheel specs anyway?
And you can go lowwwwwwwww. I discovered i can slap my rails on the ground if i wanted too. However i wont be able to drive anywhere cause my car will sit on my tyres
d2s work the same with ksports anyway. Dont they come from the same factory?
AKM83 (05-09-2011)
Old 05-09-2011, 11:41 PM   #11 (permalink)
WWDDD?
AKM83's Avatar
19x9.5 +30mm f/r varrstoens te37 reps
Glad to know I can slam it should I feel the need haha, but will prob be satisfied to go from 1.5 fingers gap I have now to about a half finger or maybe even a bit less
Can't wait to get this baby stanced out...just hope I'll have enough clearance to add an RK kit hehe
Old 05-10-2011, 12:30 AM   #12 (permalink)
Ted
mingming's Avatar
Gameroom cash: $386555
View mingming's Photo Gallery
I guess i lucked out on camber plates with the megans.
Anywho, since I want to add some camber, , would any camber bolt that is 14mm in diameter work for us? I thought the HR triple C bolts were compatible with the 07 camry, but only source that i can find says its would only work for camry 92-96.
work eurolines
mingming is offline   Reply With Quote
Old 05-15-2011, 05:31 PM   #13 (permalink)
WWDDD?
AKM83's Avatar
So I went to a shop to get aligned and have them work on my camber situation and they said I needed to get camber toe bolts in order to go to -1.5 or more. Is that true? I thought we could use our stock ones if not going beyond -2.
Are these the bolts they are referring to?
http://cgi.ebay.com/ebaymotors/Ingal...#ht_1393wt_898
Old 05-15-2011, 10:10 PM   #14 (permalink)
What coils are you on?
Old 05-16-2011, 12:09 AM   #15 (permalink)
WWDDD?
AKM83's Avatar
Private, care to share your current damping settings? I haven't really messed with them, but was curious if you found a "sweet" spot...
