Struts/springs Replaced New rattle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2011, 03:36 PM   #1 (permalink)
View 03AutoCamry's Photo Gallery
I have replaces all 4 struts and springs (new). Went with the Monroe. All went smooth but now i am getting a rattle when normal driving. Sounds like it is coming from the front two struts, near the top where the nut holding the shock shaft is. I have held the nut with a wrench and put a socket on the top of the shaft and tightened them as tight as they will go. Did I miss something when reinstalling them?
03AutoCamry is offline   Reply With Quote
Old 06-15-2011, 05:05 PM   #2 (permalink)
I'm still having this issue. I have pulled off the strut and can hit the spring with a hammer and can hear a rattle on the plate that the top of the spring sits in and the top piece that has the 3 bolts to attach to the car. If i remember correctly there is a rubber piece inside of this, do these tend to go bad or wear out? I think this may be my rattle.
Old 06-15-2011, 05:32 PM   #3 (permalink)
View Hennessy Hek's Photo Gallery
i had the same problem when i installed my new springs. it was the center bolt was loose. fixed the noise, could it be a bushing that needs to be replaced??? what yr is ur camry???
Hennessy Hek is offline   Reply With Quote
