2002 Camry driver side rear power window problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2011, 06:40 PM   #1 (permalink)
View vibhu's Photo Gallery
Hello Everyone,
I am new to this website and forums so I would like to start by saying hello to everyone here.
I have a 2002 Toyota Camry and the driver side rear power window is not working, when trying to bring the window down from either front panel or back the window does not come down.
Any DIY on this or any suggestion what would be wrong with the window. The Dealership wants 50 bucks just to see whats wrong.
Please help me. Thanks in advance.
vibhu is offline   Reply With Quote
Old 05-17-2011, 10:35 PM   #2 (permalink)
View LadyZ's Photo Gallery
That is funny I have the same problem with same window....I would love to know too.
LadyZ is offline   Reply With Quote
Old 05-17-2011, 11:26 PM   #3 (permalink)
NH603 The Crown
Mosh603's Avatar
View Mosh603's Photo Gallery
Check the fuses but most likely the window motor has failed.
Mosh603 is offline   Reply With Quote
Old 05-18-2011, 03:11 AM   #4 (permalink)
Gameroom cash: $133200
View xx03Camryxx's Photo Gallery
Yeah, check the fuses. Go in the Owner's manual and it should help you locate the fuses and just what the fuses are for. The fuses are located to the left of your steering wheel, right under the ash tray.
xx03Camryxx is offline   Reply With Quote
The Following User Says Thank You to xx03Camryxx For This Useful Post:
vibhu (05-18-2011)
Old 05-18-2011, 01:07 PM   #5 (permalink)
I will check the fuses again, but I did check them in the past.
Old 05-18-2011, 03:05 PM   #6 (permalink)
NH603 The Crown
Mosh603's Avatar
I don't think its a fuse problem. I also do not think its a wiring problem because you said it does not work with the front panel or back panel. Most likely the window motor is shot.
Old 05-19-2011, 09:27 AM   #7 (permalink)
I have checked the fuse and its not the fuse, it might be the motor. Anyone knows if there is DIY how to open the back panel and go from there.
Old 06-23-2011, 12:56 PM   #8 (permalink)
I have found out also on a how-to video on youtube that it is probably "just" that switch for the back window and not the entire motor..... I will check that out
Old 06-24-2011, 10:17 PM   #9 (permalink)
View CBonney's Photo Gallery
I had a problem like this on my 1993 camry. It was a broken wire in the wiring group that runs through the drivers side door right in the hinge. It took about 3 hours to find it and about 1 dollar to fix it with a crimp, extra wire, and electrical tape. It was the circuit return path to the drivers door switch. I didn't find it until I purchased a replacement window motor from Ebay but, it was worth it.
CBonney is offline   Reply With Quote
