2006 camry right side axle replacement help needed... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2011, 11:00 AM   #1 (permalink)
View mcgowaw's Photo Gallery
what size axle nut is on the gen 5 camry's? appears to be a 32mm 12 pt but want to be sure before i buy one because they're not easy to find in the stores. i already got a reman axle but its got the 6 pt 32mm nut that needs a retainer cap and cotter pin (but of course it didn't come with either) and my current one doesn't use one. do i need to return the axle and get one that doesn't need the cotter pin setup or just buy the nut retainer for the reman one? i didn't know if this would cause any other problems with meshing to the diff, wheel hub, etc, since it's probably from the gen 4 camry's because i seem to remember they used cotter pins.
also, please confirm its a 32, 33, or 34 mm 12 pt socket i need and also suggest a brick and mortar store where i can buy one if possible since i'd like to get it done today.
thanks much and i searched the manual and it doesn't say what size the axle nut is.
mcgowaw is offline   Reply With Quote
Old 05-29-2011, 12:19 PM   #2 (permalink)
View jtaylor6806's Photo Gallery
You no doubt figured out that the nut requires a 30mm 12-point socket. I had to order one online. Were you successful in getting your passenger-side axle replaced? I can't remove the old axle. I've beat on it with a slide hammer, but the bearing that is pressed into the frame has not budged. Did you have a trick that helped you remove the axle?
jtaylor6806 is offline   Reply With Quote
Old 05-29-2011, 07:42 PM   #3 (permalink)
Gameroom cash: $137274
View johnfrisco's Photo Gallery
How many miles--please!!!!!!!!!!!!!!!!!
johnfrisco is offline   Reply With Quote
Old 05-30-2011, 11:14 AM   #4 (permalink)
It's my wife's car, so I don't remember exactly -- about 110,000 to 120,000 miles. BTW, I had to unbolt the bracket that the bearing on the axle fits into. Then I could beat the bracket off the axle once I had it on the ground. It was still a PITA to unbolt the bracket, but it was doable. A 5 lb slide hammer never would have pulled that axle out.
Old 05-31-2011, 02:23 PM   #5 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
This is a little off the subject but something I have found useful. When I get a new car, I always spray Eastwood Anti-Rust on areas where rust build up can be a problem in the future. I sprayed the axles where they fit into the hub and the transmission and also at the support bearing. I expect the disassembly of those components will be easier when the time comes. The aerosol Eastwood product sprays on thin and has the tendency to seep into small clearances. I also works good as an undercoat product. About as durable as undercoating but not where gravel strikes the underside of the body. Keep the product off of the ABS components. I also take the brake discs off and coat the hub/disc interface with a small amount of anti-seize. Never have a problem getting the discs off as the anti-seize is a very got rust inhibitor when burnished into the hub or disc.Regards
Donald E. George is offline   Reply With Quote
Old 06-03-2011, 05:37 PM   #6 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
i had the exact same experience when i did the job on my wife's solara recently. passenger's side was a pain. beat on it, messed up a couple pry bars trying to pry it out and finally unbolted the bracket and got it off with a sledge once off the car. of course, now that i know how to do it i could do it again in 1/4 the time.
i also had to buy the socket online, can't find 12 point sockets anywhere at the local autoparts stores.
nitronate33 is online now   Reply With Quote
Old 06-18-2011, 04:41 PM   #7 (permalink)
View anthony.a's Photo Gallery
you remove a c-clip then unbolt the passenger side axle after that it should come out with no effort as there is no c clip holding it in the tranny
the axle nuts are 30mm 12 point..
If anyone has tips for removing the drivers side axle please post i cant get a grip with a pry bar
anthony.a is offline   Reply With Quote
Old 07-01-2011, 02:05 PM   #8 (permalink)
wear some mechanics gloves with good grip, grab hold of the tulip near the tranny, and yank. it'll pop right out, didn't take much for me. the c-clip is not that hard to overcome.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
