Originally Posted by BlackCam09
i have a 09 and when i took the oem filter out it had the up arrow pointing up, then i got a replacement the aftermarket frambreeze one from walmart and it said air flow with arrow pointing down, so i just put it down because the air flow is coming from top to bottom.
That is the way I see it, the airflow is down.
The factory filter simply said up with an arrow. The best install instruction.
The aftermarket throws in the confusion by printing Airflow and the arrow. That being the case, the arrow should point down with this aftermarket filter.
Thanks All!
