PLEASE HELP! Can't install new front brake pads :( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2011, 12:48 PM   #1 (permalink)
2007 Titanium Camry SE V6
View costanza's Photo Gallery
There are 2 "v" shaped spings that insert into 2 holes at the bottom of each pad, connecting them together. Am I supposed to insert the spring into both new pads and squeeze the pads together and insert them as one unit into the caliper? If so, they are like 1 mm too wide. Please help!
costanza is offline   Reply With Quote
Old 05-17-2011, 01:20 PM   #2 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
Did you compress the caliper all the way? Put the pads in the pad guides first. Then slide the caliper on top and your done.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 05-17-2011, 02:27 PM   #3 (permalink)
U dont understand. There are 2 "V" shaped springs that attach to 2 little holes on the bottom of each pad. They put outward tension on the pads, i.e. push the pads away from one another. How the heck are you supposed to reinstall the pads with the spring. It seems impossible!
Old 05-17-2011, 02:42 PM   #4 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
DIY: Brake Pad Change (56k, grab a Snickers)
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 05-17-2011, 03:01 PM   #5 (permalink)
molson.david's Avatar
Gameroom cash: $295253
View molson.david's Photo Gallery
nothing is impossible. almost.
if you left one bolt in caliper, flip caliper up, it should stay in this possition, if not- use velcro or somthing to hold it .
put both pads in place and hold them using one hand.
using other hand insert V-springs in place, one by one, keep holding pads.
lower caliper just enough to hold pads and take your hand away.
slide caliper all the way down and put second caliper bolt in place.
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 05-17-2011, 08:47 PM   #6 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
its not impossible because ive done it when i installed my ebc slotted rotors and red stuff pads. You just gotta force it in
Old 05-18-2011, 01:41 PM   #7 (permalink)
Thanks for the link with pics!!! The mistake I made was to remove the caliper AND its mounting bracket as 1 unit. This makes it impossible to insert the new pads with anti-rattle spring connecting them! Thanks so much
Old 09-12-2011, 02:06 AM   #8 (permalink)
Loving the camry =)
View skyxliner's Photo Gallery
is the anti-rattle spring mandatory? i just recently changed my pads to cheap duralast ones but they don't come with the premade holes like the factory ones do.
skyxliner is offline   Reply With Quote
Old 09-12-2011, 06:33 AM   #9 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
just use some brake grease of anti-rattle liquid, which you can find at any auto parts store, smear it on the back side of the pads, just do not over do this either... a little goes a long way.
to the O/P...in that picture from the link, you will see where the mechanic uses a C-clamp to push back the piston into its bore.
it is possible that this reply is getting to you late, (and it did, i just checked the darned date) but if you have ABS brakes..??
DO NOT DO THAT...!!!
you MUST loosen the bleeder screw at the caliper, THEN push in the piston, like in the picture...YOU WILL MESS UP the ABS systems if you do this wrong..!!!
be sure to close off the bleeder screw, AND REFILL the master cylinder
Glenn8963 is offline   Reply With Quote
Old 09-24-2011, 01:32 AM   #10 (permalink)
View yenracer's Photo Gallery
This is pretty good tutorial, but it is an old car i think. but the principle is the same. http://www.freeautomechanic.com/brake-caliper.html
it's weird that he disconnects the hose from the caliber step 6. anyone know why he did that? is that necessary for our camry?
not trying to jack your thread but didn't want to clutter up the forums with another 1.
also step 10, is he just installing a new cliper? looks pretty damn new on step 11?
yenracer is offline   Reply With Quote
