huge clunk right front wheel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2011, 03:30 PM   #1 (permalink)
knightslugger's Avatar
View knightslugger's Photo Gallery
I get a humongous clunk when i turn left and hit the lip of a drive way from time to time. speed is def. a factor in the severity of the clunk.
it makes no noise when i lift or compress the side, or shimmy it left and right.
ideas?
2009 Red Camry XLE V6
knightslugger is offline   Reply With Quote
Old 05-17-2011, 11:47 PM   #2 (permalink)
NH603 The Crown
Mosh603's Avatar
View Mosh603's Photo Gallery
Maybe an issue with the ball joint?
Mosh603 is offline   Reply With Quote
Old 05-18-2011, 12:12 AM   #3 (permalink)
08 SE
CTMike's Avatar
View CTMike's Photo Gallery
slow down hehe
WFC #495
CTMike is offline   Reply With Quote
Old 05-19-2011, 09:29 AM   #4 (permalink)
Originally Posted by CTMike View Post
slow down hehe
screw that! If you're not fast, you're last.
at any rate, i wonder if i was overloading the left front and topping out the suspension. what's the max stroke on an XLE? i should perhaps look at a lift with stronger rate springs...
Old 05-19-2011, 11:52 AM   #5 (permalink)
Gameroom cash: $122700
View mcgill_redmen's Photo Gallery
Not 100% sure but clinking noise isn't suppose / related with Front control arm or bushing?
mcgill_redmen is offline   Reply With Quote
Old 05-19-2011, 01:11 PM   #6 (permalink)
I am not really sure what you're saying here. Please improve your sentence structure, or speak your native language.
let me say it again: When I take a left turn corner hard and i hit a bump, i hear a massive clunk.
what is the stroke of the front suspension? ANYONE?
Old 05-19-2011, 03:53 PM   #7 (permalink)
View chadj812's Photo Gallery
From my experiance it's the outer tie-rod. Jack the the front up so so the wheel is off the ground on the suspected side and then try to move it back and forth with your hands at the 3 and 9 position, excessive movement points to the tie-rod, if you have have a friend or if you can see around the back of the wheel you can see the tie-rod when you do it.
chadj812 is offline   Reply With Quote
