TPMS bypass - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2011, 01:16 AM   #1 (permalink)
View srbakall's Photo Gallery
TPMS bypass
I found a thread on the Yaris forum about defeating/ bypassing the TPMS module above the glove box. Is the module in the same location in the Camry? Will this work with the 2011 Camry? I had a tire replaced 2 months ago. My light came on 2 days ago, blinking then steady. The manual says this means a fault in the system. I suspect the changed tire sensor may be the problem. I am about 1K from the 10K service interval but closer to my NYS inspection. Anyone know if this light will result in a failed inspection? After searching the net it looks like it should be a Pacific sensor.
Bob
srbakall is offline   Reply With Quote
Old 05-19-2011, 01:28 AM   #2 (permalink)
270hp = Happy Foot
Gameroom cash: $396245
View aznlunatic206's Photo Gallery
have you tried resetting the tpms system? the button in the glove box.
2011 Camry SE V6 Fully Loaded w/o Navi
V-HIDS 5000k HID Kit Low Beam, 3000k Nokya Fogs
20% Aegis Tint, 50% Front Windshield
Tein Solara Springs on KYB GR2's
aznlunatic206 is offline   Reply With Quote
Old 05-19-2011, 01:49 AM   #3 (permalink)
Tpms
Yes, I pushed the button several times and even held in in for a minute but no change. The light blinks for about a minute then steady. Repeats each on off ignition switch cycle.
Old 05-19-2011, 08:34 AM   #4 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $530410
View BlackCam09's Photo Gallery
Same thing happened to me, i had my 4 tires replaced and later during the week the light came on blinked for 1 min and stayed on, like the manual says something in the tpms is messed up. So i took my car to the dealer they said it was just the weather changing is what caused it. Then came on again so i took it back and they replaced the tpm sensors under warranty. Then it happened again and they replaced the TPMS module along the pillars near the back of the windshield and it never came back on since. I believe it was the left pillar.
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is offline   Reply With Quote
