Originally Posted by Frodo65
How and why did the cam 'let go'? Oil starvation to cam is a possible failure scenario - and it would leave tell-tale signs.
Low oil pressure can be due to a bad pump, or excessive clearances that result in flow beyond the ability of the pump to keep up with. If you truly have low oil pressure (and a direct-reading gauge is the only way to really tell), chances are that bearings are 'at risk', especially if it's been going on for so long.
Ultimately, getting at the pump, and possibly into the main/rod bearings is in your future if the pressure is below spec.
Bought it used. Ran great, didn't use any oil, no noises, no warning lights ever came on. He was driving on hiway, about 60-65, when it lost power, engine light came on, a few bucking/surges and then he heard/ felt a bang and coasted off the side of road, all this happening in less than a minute.
Dealer techs said it looked like a valve spring let go, pieces got lodged in the lobs of the front cam. Cam actually broke in two places. Made deal with dealer, if I supplied a good used head they would take care of the rest. Found head with 32K on it, they checked it out to be in excellent shape they commented it was like brand new. When head was off they looked at the cylinders to see if any damaged to walls or pistons, no damage.They replaced timing chain, tensioner etc. got car back everything seem to be ok for a few thousand miles.
Son went out of state. Sat in driveway from Sept 2010 to Jan 2011. Had to recharge battery for restart in Jan. Engine light came on and front exhaust flex joint major leak, repaired( welded new Flex section) Ran smooth, no noise nothing. Had replace battery. Went to get new inspection sticker, Had to drive it so the computer could rest for the emmisions test. After 24 miles that's when the oil light came on, engine light came on. Hooked up DRB>Cam position sensor, replaced. Had to drive again for another computer reset, same 24 miles lights came on again. Replaced oil pressure sensor, oil filter( maybe bad pressure valve in filter).
This whole time engine is running smooth with no noises, Do not hear any grinding sound at any time,like bearings, not overheating nothing. Getting oil gauge to hook up. Oil Light does not come on until driven for about 20-25 miles. What I'm thinking is maybe there is sludge problem or actual pieces from the R&R on the head replacement in the oil pan that just takes a little driving to cause a restriction in the oil pump pickup.
Does this sound logical? Any body ever seen this? Ussually dropping the oil pan is not a problem but the access to 3 bolts on the oil pan that are just above the frame are going to be a real pain in the a*s to put back in. It looks like you need to jack the engine up just an inch or 2 just to screw them back in. If this sounds like the way to go I'll do it, just hoping someone in Toyota Nation might have any other suggestions.
Thanks.
