5th Generation Camry simple mods. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2011, 12:44 PM   #1 (permalink)
iconman's Avatar
View iconman's Photo Gallery
Gen5 5th Generation Camry simple mods.
First up changing the front grille from a 2002 to a 2005 model Camry LE/XLE. Ordered the grille from RockAuto. The fit and finishes was alright. Inspired by another member on TN. The new grille looks elegant and sexy.
I also ordered a Valor exhaust tip from TRDparts4u. Installation was a breeze.
Updates:
This mod is to add a protection screen to the AC's condenser behind the grille from road debris that could potentially damage it when you're on the road. I might try this on the front bumper when I have time. I think this mod will work with most if not all cars. I got the idea from another car forum.
You will need a gutter mesh guard , zip ties, something to trim the mesh with and a drill with a drill bits to drill couple of holes large enough for the zip ties to go through.
I got the Amerimax gutter guard from Ace Hardware. It is made of durable plastic and came in black. Zip ties I bought from Home Depot and a dremel with cutting blade and drill bits.
All the red marks are where I'm going to drill a hole through the grille's tabs with the dremel. There are going to be a total of 18 holes.
Front
Back
Closer look of the drilled hole through the tab.
Starting to trim up a bit and secure the mesh guard with the zip ties through the drilled tabs.
Done
Took me about an hour and a half but that mainly because this was my first time using a dremel tool.
The mod doesn't mess up the look of the grille at all since and the only way to tell that it has been modifies is if you stand very close trying to look for the zip ties.
June 12 updates
I decided to Plasti Dipped the OEM Camry's alloy rims. I got a couple cans of the black Plasti Dip from Home Depot and a can of RustOleum acrylic enamel clear coat. I started the project on Saturday afternoon and finished by Sunday night.
The only prep work I'd done was washed the rims and tapped off the wheels and spokes with newspapers. There were no sanding and primer involves.
I jacked up the car and took off all four wheels. I started off with a light coat of the Plasti Dip, let it dried for about 45 minutes and then sprayed it again but this time with a medium coat. The remaining three cans of PD I repeated this cycle with medium coat each time.
This morning the PD cured and I did a few coats of the RustOleum clear coat. The PD itself is matte black but with the clear coat there is a bit of gloss.
I heard that the PD was durable and could be taken off easily, kind of like vinyl wrap. Just be sure to layer at least a couple of coats of PD on whatever you're spraying it on so that it would peel off in one big chunk instead of flaking into tiny pieces when you want to remove it.
Overall I am happy with the result.
Before Plasti Dipped
Materials
First light coat of PD
Medium light coat
Cured PD waiting for clear coat
Added clear coat looks kind of glossy
Careful taking of the newspapers or this could happens
Finish results
iconman is offline   Reply With Quote
Old 05-27-2011, 06:19 PM   #2 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
looks good..... i ordered a new grille from rock auto that i painted and it turned out great
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
Old 05-27-2011, 06:47 PM   #3 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1077958
iTrader Score: 7 reviews
Good stuff... nice simple and clean.
2002 Camry SE V6 "Snow White"
Old 05-27-2011, 09:13 PM   #4 (permalink)
View orton's Photo Gallery
Wow that 2005 grille looks a lot better
orton is offline   Reply With Quote
Old 05-27-2011, 09:37 PM   #5 (permalink)
Gameroom cash: $133200
View xx03Camryxx's Photo Gallery
You made me want this grille, just bought it.
xx03Camryxx is offline   Reply With Quote
Old 05-27-2011, 09:56 PM   #6 (permalink)
View boonkai's Photo Gallery
how you change the muffle tips? you do it yourself??
boonkai is offline   Reply With Quote
Old 05-27-2011, 09:58 PM   #7 (permalink)
it slides over the tailpipe and bolts on
Old 05-27-2011, 10:57 PM   #8 (permalink)
where did u get that from? ebay?
Old 05-27-2011, 11:11 PM   #9 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $150432
View Yazovets's Photo Gallery
Looks good! I like simple mods like this.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 05-28-2011, 04:00 AM   #10 (permalink)
"GEN5CAM"
Gameroom cash: $129550
View Gen_5's Photo Gallery
Nice clean mods! Where in the Bay Area are you located ?
Gen_5 is offline   Reply With Quote
Old 05-28-2011, 06:35 AM   #11 (permalink)
iconman's Avatar
I live in Oakland. Right now I'm just waiting for the S2K-r projectors development stage to complete so I start the HID retrofit with them.
Old 05-28-2011, 01:24 PM   #12 (permalink)
I Eat Accords! W_(^_^)_W
my.rims.are.stock's Avatar
Gameroom cash: $114800
View my.rims.are.stock's Photo Gallery
Question
You take this car to the side show?
my.rims.are.stock is offline   Reply With Quote
Old 05-31-2011, 01:09 AM   #13 (permalink)
iconman's Avatar
Updates
Old 06-06-2011, 09:55 PM   #14 (permalink)
View restrung's Photo Gallery
can you possible tell me the exact grille you got from rockauto? and all the pictures on this site don't have the toyota emblem in it. do you have to install that separately or what?
restrung is offline   Reply With Quote
Old 06-06-2011, 10:01 PM   #15 (permalink)
u havta reuse ur old emblem or buy a new one
