Any strut install how-to's? Also strut mounts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2011, 07:43 PM   #1 (permalink)
PatrickGSR94's Avatar
View PatrickGSR94's Photo Gallery
Well my mom's 2007 V6 XLE will be getting new struts soon, and I wanted to do research before she gets to that point. Are there any strut installation DIY's or how-to's around here? Searching didn't bring up any how-to threads. I took a peek behind the wheels the other day and it looks like the brake line bracket on the front struts is such that the line can be removed without disconnecting the lines from the calipers. However the rears look like they'll either have to be disconnected or the brackets cut that hold the lines in place. What's the preferred method there?
Can't understand why Toyota is still using this dumb@$$ design for holding the brake lines in place
Also what about new strut mounts? I checked Rock Auto but it seems like they only have the rear upper mounts available. What about the fronts?
PatrickGSR94 is offline   Reply With Quote
Old 05-31-2011, 10:20 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Try this:
http://www.toyotanation.com/forum/t249792.html
Yeah, Monroe has only the $40 rear mounts that's been used since Gen 4. You can check with ToyotaPartsMan for OEM mount prices or try one of the online Toyota dealers.
So what struts will she be getting?
Old 05-31-2011, 10:38 PM   #3 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
i did lowering springs on my gen 5 and it wasnt too bad at all.... i didnt replace my struts but i highly recommend kyb
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
Old 06-01-2011, 09:30 PM   #4 (permalink)
Awesome so it looks like the brake lines have bolt-on brackets on all 4 corners? That would be perfect.
Struts, probably just any old OEM replacement, KYB or Monroe or whatever. Nothing special.
Old 06-01-2011, 09:54 PM   #5 (permalink)
yea the brake lines and abs wires are just bolted on..... sway bar links are a bit of a pain but not too bad
Old 06-01-2011, 10:07 PM   #6 (permalink)
nothing my impact can't take care of!
Old 06-03-2011, 09:52 AM   #7 (permalink)
Bills07CamLE's Avatar
Gameroom cash: $220300
View Bills07CamLE's Photo Gallery
Check amazon I got the mounts for like 20 bucks each and I think like 75 for each (Monroe) strut. You can get all 4 kyb's on ebay for like 360 or so.
Bills07CamLE is offline   Reply With Quote
Old 06-03-2011, 12:11 PM   #8 (permalink)
View 89molavi's Photo Gallery
So anybody else done the DIY? I am in need of changing the 4 on my LE and also noted that amazon has the KYB's for the best price plus free shipping. Now I am not going to risk my life with the spring compressor, also would have to buy sockets because my 3/4" only goes as high as 19mm. So I am trying to see if it is going to be worth the hassle plus extra for tools and also paying someone else to assemble the struts. Anybody tackled this without an impact wrench? On the positive side, my car is a California car, so hopefully less rust issues to deal with.
89molavi is offline   Reply With Quote
Old 06-03-2011, 12:20 PM   #9 (permalink)
1. go with kyb
2.the spring compressor honestly isn't that bad if your carefull
3. i think it's always worth the hassle to work on ur own car because if its a job you can do yourself, you will save lots of $ and learn something in the process
4. and u MUST use an impact gun; u will not be able to get the lower strut bolts off without one, plus it made the spring compressor job much easier; i borrowed mine from work but u can probably rent one
Old 06-03-2011, 12:33 PM   #10 (permalink)
'11 Camry SE
exclusive's Avatar
Gameroom cash: $305680
View exclusive's Photo Gallery
Wrong...A breaker bar combined with some liquid wrench/wd-40 will take care of them
2011 Camry SE
|| Click my car below to see my thread ||
exclusive is offline   Reply With Quote
Old 06-07-2011, 01:30 PM   #11 (permalink)
View Den49's Photo Gallery
At 60,000 miles, I replaced all four struts myself on my 2007 I4 XLE Camry with KYBs and new front strut bearings because the left front strut was leaking and causing the car to ride and handle poorly. It cost me about $500 for the parts and an alignment, vs. $1,500+ to have it done by the dealer or a good independent who would do the job correctly. I am very happy I did it myself because the car rides and handles better now than when it was new, I saved a ton of money and I have a huge sense of satisfaction that I did it myself.
The best information you can have for this job is the Toyota service manual. It leads you step by step through the operation. If you are adequately skilled and follow the steps in the manual, you should not go wrong. There are on-line versions of the service manual that you can download for $20. The spring compressor is not as dangerous as often feared if you use it carefully and correctly, i.e: bolt the bottom of the strut into a wood block jig, clamp the wood into a good vise, lubricated the threads of the compressor with light oil; use an air ratchet (NOT an impact wrench) to turn the compressor bolts/screws. Obviously you also need the proper tools and equipment to do the entire job, including lifting the car safely.
If you don't have all of the above, you probably should not attempt the job. Safety first.
Edit: The reason that you should not use an impact wrench on the spring compressor is that it can spin the nuts too fast, strip the threads and cause the whole thing to fly apart. The air ratchet spins slower, thus safer, and works quite well.
Den49 is offline   Reply With Quote
