07 Camry Water Pump - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2011, 04:27 PM   #1 (permalink)
View blkavalon's Photo Gallery
07 Camry Water Pump
Any of you guys have premature water pump failures on your Camry. i work at Advance auto this is the 3rd 07 Camry water pump that i have sold with in last 4 months i would say. today my friends Camry started leaking and it has 50k miles. my 91 camry still runs on original water pump while 17 years younger car having problems.
98 Avalon XLS, 91 Camry, 78 Corvette, 92 Saab 900,
05 Yamaha R6 Raven, 81 Suzuki GS 650L,
blkavalon is offline   Reply With Quote
Old 06-02-2011, 07:28 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Some fail 1/2 that mileage. Must be cost cutting.
Or maybe the 5-year pink coolant isn't doing its job? Dunno. IMO the original red, even if only good for 2 years, is a better coolant.
Old 06-02-2011, 08:02 PM   #3 (permalink)
molson.david's Avatar
Gameroom cash: $295253
View molson.david's Photo Gallery
2007 pump has been replaced at 74K.
on 2001 model pump was replaced at 90K.
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 06-02-2011, 11:30 PM   #4 (permalink)
Camry Freak
98CamryLE's Avatar
View 98CamryLE's Photo Gallery
Mine failed at about 58K miles under warranty. The dealer said that it is a very common issue. I recommend that any 2007-2011 Camry owner keeps an eye out for pink coolant leaks under the hood, especially as you approach the end of your powertrain warranty.
2007 Camry Hybrid
98CamryLE is offline   Reply With Quote
Old 06-03-2011, 12:57 AM   #5 (permalink)
Joined the dark side. :D
Gameroom cash: $656491
View workerant's Photo Gallery
V6 or I4?
workerant is online now   Reply With Quote
Old 06-03-2011, 11:28 AM   #6 (permalink)
Gameroom cash: $220500
View winstead22's Photo Gallery
2007 Camry Se I4, went out at 21,000 miles, replaced under warranty.
winstead22 is online now   Reply With Quote
Old 06-05-2011, 09:30 PM   #7 (permalink)
Originally Posted by workerant View Post
V6 or I4?
Mainly I4.
Old 06-05-2011, 09:56 PM   #8 (permalink)
07 Camry I4
kaashifv's Avatar
Gameroom cash: $197430
View kaashifv's Photo Gallery
I have a 2007 Camry I4 with 91000km and still the original water pump...maybe my time is coming soon...lol
kaashifv is offline   Reply With Quote
Old 06-06-2011, 07:26 AM   #9 (permalink)
View Den49's Photo Gallery
The Toyota pink coolant is a similar type of coolant as the GM Dexcool (OAT). I am on my second replacement water pump for my I4 Camry at 60,000 miles. On a previous Buick LeSabre with Dexcool, I had to replace the water pump twice within about 3 years and 50,000 miles, then I flushed out the Dexcool and replaced it with the green/gold Prestone Longlife coolant. After that the waterpump and the rest of the cooling system gave me no problem and was good when I got rid of the car at 10 years and 165,000 miles. I am again thinking that the Camry pump failures are being caused by incompatibility between the coolant and the water pump pump seals. Not sure at this point if the Camry water pump fails again whether I will change the coolant to Prestone or try another brand of water pump. Any suggestions?
Den49 is offline   Reply With Quote
Old 06-08-2011, 07:37 AM   #10 (permalink)
ARCamry07's Avatar
View ARCamry07's Photo Gallery
Waterpump Replacement
I have an 07 4 cylinder Camry with 38K miles, and just had my waterpump replaced under warranty this week. It was weeping ,leaving pink crystals on the bottom side of the water pump, but never a drop of coolant on the floor. I would have to add a quart of water every now and then. I also had the tell tale pink stripe on the underneath side of the hood on the lining, where the leaking coolant gets slung up there.
They replaced the water pump, long life coolant , and also the accessory drive belt ( at my request) for $44 total. Couldn't beat the price, but I too am wondering about the short water pump life.
ARCamry07 is offline   Reply With Quote
Old 06-08-2011, 08:06 AM   #11 (permalink)
38K is about the same mileage as when my original water pump failed on my 2007 I4 Camry. It was also replaced under warranty with a Toyota water pump. Hopefully, the water pump you received has been improved.
Old 06-08-2011, 12:37 PM   #12 (permalink)
ARCamry07's Avatar
Water Pump
Yeah, 38000 miles is a pretty short life for a water pump, maybe the new one will get better mileage
Old 06-08-2011, 12:57 PM   #13 (permalink)
Will
willt's Avatar
iTrader Score: 7 reviews
View willt's Photo Gallery
not about water pump but question but about coolant reservoir its seems mine is always low do i have to worry about this? also sometimes i see coolant sprays underneath the hood let me know what you guys think?
L-OO-k at MEE...
willt is offline   Reply With Quote
Old 06-08-2011, 01:37 PM   #14 (permalink)
^ u r not afraid your engine will over heat?
Old 06-08-2011, 09:12 PM   #15 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
my 06 waterpump went at 48k
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
