2003 Camry XLE - Rust on Rear Door Handles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2011, 06:23 PM   #1 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
Don't know if anyone is this forum has experienced this and knows how to fix it, but I am getting rust bleeding out from the rear driver's door handle on my 2003 Camry XLE. The rear passenger door is actually just starting to do the same. A friend of mine said about a year ago his was doing the same, but I never found out what he ended up doing, if anything, to correct that.
Anyone know what's going on with that, and what is the best way to stop the rust bleeding at the door handle?
93celicaconv is offline   Reply With Quote
Old 06-06-2011, 08:52 PM   #2 (permalink)
Bump.
Am I the only 5th Gen Camry owner in this forum experiencing this problem?
Old 06-07-2011, 10:50 AM   #3 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Sometimes it's helpful to wait more than a day for a response
The last time I heard about this problem, the door handle was taken off and everything was cleaned inside.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 06-07-2011, 10:58 AM   #4 (permalink)
Joined the dark side. :D
Gameroom cash: $656491
View workerant's Photo Gallery
I thought it's helpful to start several new threads. j/k
homedepot have some paint that you can use to prevent rust. Of course you have to remove the handle and do the painting. I'm thinking of doing this too, but at the vent.
workerant is online now   Reply With Quote
Old 06-07-2011, 10:03 PM   #5 (permalink)
I suppose a stupid question, but what in the door handle would cause the rust stain? I've never seen this on other cars. That's because there isn't supposed to be anything on the outside of the handle that can rust, and the handle itself is sealed around the door opening. Anything that can rust is on the inside of the door. So where does the rust stain come from to get on the outside of the door?
Old 10-08-2011, 01:28 PM   #6 (permalink)
View Camry2004's Photo Gallery
Originally Posted by 93celicaconv View Post
Bump.
You are not alone. There are a lot of people with this problem. Toyota dropped the ball on this one like they did with the gas pedal.
How did you fix it?
I seriously think Toyota MUST fix this rust problem even if the warranty is over. They literally screwed up the non-galvanized nut/bolts. I am hearing a lot of complain on this. There has to be a class action lawsuit.
Camry2004 is offline   Reply With Quote
Old 10-09-2011, 11:37 AM   #7 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
Eastwood makes a product that it an aerosol anti-rust. Comes in black and amber. The wax like product sprays on very thin and seals very small opening. I sprayed the CV joints and axles on my 04 right after I purchased it and those units show no rust. Same with some of the other suspension members that rust if not protected. You might locate the source of the rust and use this spray to stop the rusting.Regards
Donald E. George is offline   Reply With Quote
