Custom intake help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2011, 02:59 PM   #1 (permalink)
View mrvvti29's Photo Gallery
Custom intake help
I have a 11 4 cyl 2.5l camry. I was able to get on short ram with all of the stock casings but since the sensor did not fit snug the check engine light turned on that same night. I was able to see a few posts and check out the parts needed but not exact parts needed to make the custom intake. So far I got the air filter but need the pipe and the housing for the maf sensor which i found on jegs.com thanks to other posts found on the site. Spectre 9405 - Spectre Modular Air Intake System & Accessories. Any help would be great. Thanks
mrvvti29 is offline   Reply With Quote
Old 06-07-2011, 03:52 PM   #2 (permalink)
'11 Camry SE
exclusive's Avatar
Gameroom cash: $305680
View exclusive's Photo Gallery
I'm going to build one for mine soon also.
I believe you will need this for the MAF:
http://www.autozone.com/autozone/acc...er=939537_0_0_
2011 Camry SE
|| Click my car below to see my thread ||
exclusive is offline   Reply With Quote
Old 06-07-2011, 05:09 PM   #3 (permalink)
Bills07CamLE's Avatar
Gameroom cash: $220300
View Bills07CamLE's Photo Gallery
I just made mine not to long ago with autozone parts.
Here is a list of what I used.
1 - #8751 coupler kit
2 - #8738 45 degree tubes
1 - #9405 MAF sensor mount
and the filter of your choice.
1 - Small Breather filter also (that you will connect into the loose tube you will see once you take everything from the OEM intake out)
Connect in that order to!
The sensor mount you have to get at JEGS because Autozones supplier is out of stock so they cant even special order it. Happy tuning!
Bills07CamLE is offline   Reply With Quote
Old 06-07-2011, 10:36 PM   #4 (permalink)
muckdawg24's Avatar
View muckdawg24's Photo Gallery
what's the gain at the wheel with the custom intake?
muckdawg24 is online now   Reply With Quote
Old 06-07-2011, 10:41 PM   #5 (permalink)
11LE's Avatar
Gameroom cash: $244400
View 11LE's Photo Gallery
Most likely nothing. On a good day, 1-2 hp?
Super White 2011 LE
|Debadged|-|4300k HID's|-|Tinted|-|Wheel Pkg|-|OEM Tip|-|Covered Squirrel Spotters|-|Yakima Rack System|-|Illuminated Cup Holders|
11LE is offline   Reply With Quote
Old 06-07-2011, 11:21 PM   #6 (permalink)
Yeah no real gains its more so for the sound but even with a K&N that says you get 14hp its not till you are in the 5k rpm range that you get real gains. So no real gains with those unless you drive like a mad man all the time.
Old 06-08-2011, 12:12 AM   #7 (permalink)
Joined the dark side. :D
Gameroom cash: $656491
View workerant's Photo Gallery
^ maybe that's why I feel the V6 didn't fully kick in until it reach around 80mph. Below that it feels like a pig hauling all the weight. But that was OEM intake.
workerant is online now   Reply With Quote
Old 06-08-2011, 08:28 PM   #8 (permalink)
muckdawg24's Avatar
K&N stated 14hp on an I4 for a drop in filter? What a crock of dung. Have to be WOT.
I'll agree, it does sound cool though.
Old 06-08-2011, 09:06 PM   #9 (permalink)
Well its 14hp gain with the short ram intake not the drop in but still like I said u only have gains at 5+k rpm.
Old 06-08-2011, 10:01 PM   #10 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $821521
iTrader Score: 16 reviews
View GT-R's Photo Gallery
I have K&N SRI and drive like a mad man all the time.
Oh, just hit 11,000 miles with the SRI and no check engine light at all.
GT-R is online now   Reply With Quote
Old 06-09-2011, 12:18 AM   #11 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
I had a custom SRI on my 2.4L accord, similar specs to the 2.4 camry.
With the sri, it sounded loud and mean. But really , its so loud but you got no where fast :P
Recently put on my stock intake with out the resonator, its a bit quieter but sounds mean. Gained some lower end back and lost a bit of higher end, the opposite was gained with the sri. I do a lot more in town driving, stop and go etc. The low end power seemed more reasonable to me and I wish I converted back to stock sooner!
CamrySExxx is offline   Reply With Quote
Old 06-10-2011, 08:16 PM   #12 (permalink)
11LE's Avatar
I've heard o loss of low end or torque from a really unrestricted exhaust (experienced this one myself) due to reduced backpressure, but how does a sri bring down low end? Does it throw off the a/f ratio so much that the ecu can't adjust enough or something? Curious!
Super White 2011 LE
