I believe stock wattage for the 9005 is 65 watts so there may be a typo in the manual. You won't have a problem with Crystal Vision bulbs, they are considered a stock replacement. The problem you will have is buying 9006's for the low beams. Your car takes H11 bulbs in the projector beams, not 9006's. A better mod for the low beams is to modify H9 bulbs to fit in the H11 slots. A quick search will turn up the modification procedure, I've been runnung them for over a year now. I use Hella H9's and light output is much better than stock.
05 Highlander V6 AWD
170K miles young
07 Camry SE V6 SOLD!!
TRD Dual Exhaust & Air Filter
