check engine light when gas tank 1/3 full - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2011, 11:12 PM   #1 (permalink)
View 1956kiteboarder's Photo Gallery
Gen6 check engine light when gas tank 1/3 full
Hey, my 2008 camry v6 se , check engine light comes on when gas tank is 1/3 full, it self resets after two days, then comes back on if I have not filled up the tank. Will stay off untill i reach 1/3 tank or less.
Any ideas?
1956kiteboarder is online now   Reply With Quote
Old 06-11-2011, 11:21 PM   #2 (permalink)
Rey
Pilot0617's Avatar
Gameroom cash: $148000
View Pilot0617's Photo Gallery
check the gas cap
09 Camry Full Gen 6.5 conversion/4300K HID low beams/3000K HID Fogs/Borla exhaust/ 35 tint all around/Auto folding mirrors/Full led conversion/ K&N drop in filter/ Flux capacitor to make it go faster.
Pilot0617 is offline   Reply With Quote
Old 06-11-2011, 11:27 PM   #3 (permalink)
Originally Posted by Pilot0617 View Post
check the gas cap
Yes, I did, it is tighter than the one click it says to tighten.
If I fill up the tank all the way, and tighten the gas cap like normal all thease 48,000 miles and then this starts happening after a full fill up and then the light comes on when I am down to 1/3 of a tank. Same hand tightening the gas cap all the last three years.
can a gas cap go bad?
Old 06-12-2011, 08:42 AM   #4 (permalink)
gator1939's Avatar
Gameroom cash: $245335
View gator1939's Photo Gallery
http://www.ehow.com/list_7397264_bad...-symptoms.html
http://www.askpatty.com/faq.php?ID=3...20gas%20cap%3F
http://everything2.com/title/Gas+cap
http://www.aa1car.com/library/evap_system.htm
Answer, yes, a gas cap can go bad.
gator1939
2B1ASK1
gator1939 is offline   Reply With Quote
Old 06-13-2011, 02:39 AM   #5 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
Any ideas?
You have noticed a pattern to the problem.
But you need to get the code to verify the problem and you might be looking at the wrong system and the pattern just might be a coincidence....
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 06-13-2011, 12:51 PM   #6 (permalink)
Gen6
I bought a new gas cap at kragen for $9.30 including tax.
Will see if the light stays out.
I had an appointment at the toyota dealer but the light needs to be on with less than a third of a thank of gas for them to look at it.
Old 06-13-2011, 03:41 PM   #7 (permalink)
The light came back on, a new gas cap did not solve the problem, going into the toyota dealer tommorrow.
Old 06-13-2011, 10:06 PM   #8 (permalink)
Gameroom cash: $169021
View Dave-o's Photo Gallery
when you pump gas, does the pump auto-stop before it should?
Dave-o is offline   Reply With Quote
Old 06-13-2011, 10:18 PM   #9 (permalink)
Gen6
It fills up normally.
Old 06-13-2011, 10:27 PM   #10 (permalink)
theres a relay underneath the car which alleviates pressure inside the tank and if it goes bad, a chk engine light may come up
there must be something wrong with the fuel pressure
Old 06-14-2011, 11:37 AM   #11 (permalink)
The car is at the dealer, I have a estimate of $140 to diagnose that would be forgiven if propblem is under warrenty.
My 36, 36,000 is expired, but I still am covered on the power train and major cost emission control in california.
California Emissions Warranty –
Under the California Emissions Warranty, vehicles certified for sale in California, and those states like Vermont that have adopted California Emissions Standards by law, have additional coverage beyond that required under Federal law. Under the California Emissions Warranty, all emissions related parts are covered for 3 years or 50,000 miles*, and a vehicle-specific list of more expensive emissions related parts is covered for 7 years or 70,000 miles*. In addition, the 8 year or 80,000 mile* coverage for the catalytic converter and engine control unit required by Federal law also applies.
Old 06-14-2011, 03:28 PM   #12 (permalink)
Gen6
here is the scoop!
I was charged $140 at TOYOTA MARIN for diagnostic.
They say it code po161 and recommend changing oxygen sensor bank 2 sensor 2 heater curcuit failure . repair estimate $310
That part of the emmision control is only covered 3years or 50,000 miles.
So I am out of luck there.
In hind sight if I had known it would not be covered under warrenty. I could have taken the car to Japan motors down the street and could have gotten it fixed for less as they do not charge seperate for diagnostic.
Old 06-14-2011, 04:01 PM   #13 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
some places even offer free scans, also for 140 you probably could have bought a lower end obd2 scanner.
CamrySExxx is offline   Reply With Quote
Old 06-14-2011, 04:12 PM   #14 (permalink)
yes, i could have bought a scan tool for that price.
onward, were exactly is the sensor , bank 2 sensor 2?
Old 06-14-2011, 06:22 PM   #15 (permalink)
View TOYOTAndy's Photo Gallery
On the 2GR-Fe V6 Bank 2 is the front side closest to you and the sensor you can see from under the hood- That is sensor 1, but you need sensor 2. Sensor 2 is down underneath in the pipe. Probably have to remove skid plate to see it. If i remember right bank 1 sensor 2 is also down near the same place but it is in the pipe that goes to the rear Bank (Bank 1)
Not too bad at all if you have basic tools and pickup an o2 sensor tool, save yourself another $100 labor, then go to autozone etc have them clear the code or just disconnect battery for a minute. Good luck
TOYOTAndy is offline   Reply With Quote
