My Tein Springs is Making a Clunk Noise? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-14-2011, 12:00 AM   #1 (permalink)
Platium Member
Importz's Avatar
View Importz's Photo Gallery
Gen6 My Tein Springs is Making a Clunk Noise?
Hey guys, I just recently installed my Teins springs and now I am noticing that when I drive in and out of my drive way I hear this clunk sound. This only happens when i go over a bump in and out of my driveway... Anyone having this problem?? plz help
The best way to describe the sound is like metal touching metal...a grinding noise..
2011 Toyota Camry SE V6
Importz is offline   Reply With Quote
Old 06-14-2011, 12:38 AM   #2 (permalink)
270hp = Happy Foot
Gameroom cash: $396245
View aznlunatic206's Photo Gallery
Its normal.
2011 Camry SE V6 Fully Loaded w/o Navi
V-HIDS 5000k HID Kit Low Beam, 3000k Nokya Fogs
20% Aegis Tint, 50% Front Windshield
Tein Solara Springs on KYB GR2's
aznlunatic206 is offline   Reply With Quote
Old 06-14-2011, 12:57 AM   #3 (permalink)
Platium Member
Importz's Avatar
Originally Posted by aznlunatic206 View Post
Its normal.
But it doesnt sound too healthy thou.. lol ... Can anybody else chime in?
Old 06-14-2011, 01:02 AM   #4 (permalink)
Joined the dark side. :D
Gameroom cash: $656491
View workerant's Photo Gallery
Its normal.
oem don't have that sound. it's an air compress kind of sound but it's soft.
workerant is online now   Reply With Quote
Old 06-14-2011, 01:14 AM   #5 (permalink)
Avy
Gameroom cash: $819455
View pmesfun's Photo Gallery
Clunking usually comes from bad strut mounts, but your car is new, still possible though. I would check if all disturbed parts are tight.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 06-14-2011, 08:43 AM   #6 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1077958
iTrader Score: 7 reviews
+1
Check your strut mounts... My strut mount broke and it was horrible everytime i turned...and i didn't catch it quick enough..it actually broke my spring in half.
So get it checked asap.
2002 Camry SE V6 "Snow White"
Old 06-14-2011, 10:50 AM   #7 (permalink)
View Hennessy Hek's Photo Gallery
Try to tighten the center big bolt on top of the strut. Which one is it happening to??? i just installed springs on my car last week and i had the same problem with the front passanger one. I had apparently not tighten then center bolt which caused the same sound of rubbing from the bushings to strut. try that out i hope it works!
If not that it might be the bushings
Hennessy Hek is offline   Reply With Quote
Old 06-14-2011, 12:08 PM   #8 (permalink)
270hp = Happy Foot
So im confused, i know this is a little different but i have solara tein springs and when i make turns i hear a clunking noise, but when going over bumps and what not its fine. Do i also have this issue with bad strut mounts?
Old 06-14-2011, 12:14 PM   #9 (permalink)
Just check the center bolt and make sure it's tight and not loose. What's so confusing about it. It could be other things just go dwn the list into u figure out which on it is. U don't need to remove nothing to do this. Mad easy
Old 06-14-2011, 12:29 PM   #10 (permalink)
Mine was the passenger side front...it did the same thing, turning it was a loud clunk but going straight and over bumps it was fine.
Old 06-14-2011, 12:42 PM   #11 (permalink)
Workin' on it.
Musicmansell's Avatar
Gameroom cash: $144751
View Musicmansell's Photo Gallery
Just my two cents...I just had H and R springs installed and it took a couple weeks or more for all the pops and creaks to work there way out. That might be it, your car is just settling in. I also noticed when my mechanic and I were doing this he cut the white rubber bumpers in half. I asked why and he said, alot of guys put springs on but don't think to cut this part to fit better with the lowered car. What results is a strange bump or grinding type noise when you ride over bumps. Could this be it? Just trying to help.
Musicmansell is offline   Reply With Quote
Old 06-14-2011, 12:57 PM   #12 (permalink)
Platium Member
Importz's Avatar
Heys guys, just took the car into the shop, apparently the center strut bolt is not tight enough... He told me to drive around for a week and see if it goes away if not take it too him and he will take it apart and retighten it!!
BTW my friend was the one that installed the springs... My ex friend I should say!! lol..
And yes Musicmansell is correct!! My mechanic told me to always cut the bumpstop if you are putting on lowering springs which I did!!
Old 06-14-2011, 01:12 PM   #13 (permalink)
Like I said it was the bolt. No biggie it should be fine like mine
Old 06-14-2011, 01:15 PM   #14 (permalink)
Workin' on it.
Gen6
glad you pin pointed the problem. Hope it works out ok for you bro!
Old 06-14-2011, 01:18 PM   #15 (permalink)
Avy
Wow, I was going to lower my avy next week and I didn't know about cutting the bump stops, glad I know now.
99 Avalon XLS-149k
99 Lexus LS400-88k
