engine wont start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-16-2011, 02:56 PM   #1 (permalink)
View shikbas's Photo Gallery
engine wont start
Hi ,I need your help please,i replased the battery on my 02 camry xle,engine will start but will die immediately unless i push the gas,autozone checked the battery/alternator fine,checked the computer no saved codes...
Your suggestions please
shikbas is offline   Reply With Quote
Old 06-16-2011, 03:06 PM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
Assuming it was running properly before the battery came out, the computer lost its memory when you disconnected the battery. Start it up, use both feet to idel it and drive around for awhile. All should be good in half an hour.
gdanaher is offline   Reply With Quote
The Following User Says Thank You to gdanaher For This Useful Post:
Donald E. George (06-17-2011)
Old 06-16-2011, 03:11 PM   #3 (permalink)
thank you,it was running properly
Old 06-18-2011, 08:48 AM   #4 (permalink)
ok guys i am back,i fixed the car,cleaned the af sensor and the throttle body,car started like new,,,,,thank you for your support
Old 06-18-2011, 09:26 AM   #5 (permalink)
View AlmightyCamry777's Photo Gallery
All's well that ends well, good call gdanaher! I have a 2002 as well, a V6, and i have disconnected the battery plenty of times and never once had this problem. I wonder why this would happen on one 2002 and not another.
AlmightyCamry777 is offline   Reply With Quote
Old 06-18-2011, 11:51 AM   #6 (permalink)
DftMachine's Avatar
View DftMachine's Photo Gallery
Yup. My 05 LE did that when I disconnected the battery. I just sat in the driveway and kept the rpm above 1k for a couple minutes using the throttle. I guess the car just has to relearn where idle is
2011 Kia Optima LX 6MT - 18" Kia Factory Rims - K Rebadge - Lowering Springs (Shipped) - Tint (Soon)
DftMachine is offline   Reply With Quote
Old 06-18-2011, 01:12 PM   #7 (permalink)
Maven
gdanaher's Avatar
The computer has a default setting and must compensate for small variations in the sensors and other inputs. If things are quite a bit out of tolerance at some point then it isn't going to work well until the parameters are set back to accomodate those variances.
