Different kind of Spring Question: Raising the Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-16-2011, 04:51 PM   #1 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
Gen5 Different kind of Spring Question: Raising the Camry
This is different kind of spring question than usual. Basically I need stiffer rear springs without lowering it, or taller springs in the back. A little background. I have an 04 4cly Camry, with 250K miles on the clock. I have a hitch and that bit that goes under the tail pipe is always dragging, even when unloaded. I regularly carry at least 4 people in the car, and that just exacerbates the problem. It's even worse when towing with either stuff in the car or stuff on the roof rack.
I've looked high and low, all of the springs that are stiffer, also lower the car, which would make it worse. From what I can tell, the ES and the V6s all share the same spring. I guess my question is, does someone make a spring that is stiffer or taller, or will the springs/struts from a highlander or another Camry based CUV work?
drunken_panda is offline   Reply With Quote
Old 06-16-2011, 04:53 PM   #2 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1077958
iTrader Score: 7 reviews
Coilovers...
2002 Camry SE V6 "Snow White"
The Following User Says Thank You to Punks_Not_Dead5 For This Useful Post:
Lauren (06-18-2011)
Old 06-16-2011, 08:56 PM   #3 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
^agreed, coilovers.
most coilovers allow you to customize the spring rates, so you can go as stiff as you want in the rear, without sacrificing ride height. my bc coilovers allow me to go nearly to stock height down to very very low (which i don't, because i like to be able to drive my car).
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 06-17-2011, 11:30 AM   #4 (permalink)
molson.david's Avatar
Gameroom cash: $295253
View molson.david's Photo Gallery
Also you can use polyurethane inserts, they go between shock mounts and body. Some of them 2.5” tall.
4x4 customizing shops can make and install them. You also will need longer screws and alignment.
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 06-21-2011, 11:59 AM   #5 (permalink)
Iron Chef IV
I've thought about coilovers, but my camry does have 250K miles on the clock so I can't really see making that big of an investment. That's why I was looking at just different springs.
I will look into the Poly inserts. Thanks!
