head light issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2011, 08:39 PM   #1 (permalink)
View Rheezie's Photo Gallery
head light issue
I have a 2007 toyota camry se, on my front headlights where the bulb connects to headlight assembly it is broken and no longer holds the bulb in place. Do I need to replace the entire headlamp or is there a way to fix this. currently using electrical tape. Thanks ahead of time.
Rheezie is offline   Reply With Quote
Old 06-20-2011, 08:58 PM   #2 (permalink)
Gameroom cash: $418500
View tengiday's Photo Gallery
Any pictures?
tengiday is offline   Reply With Quote
Old 06-20-2011, 08:59 PM   #3 (permalink)
molson.david's Avatar
Gameroom cash: $293553
View molson.david's Photo Gallery
it depend how and where exactly it broken.
try to find broken off piece and glue it in place.
high temp epoxy should work.
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 06-20-2011, 09:18 PM   #4 (permalink)
http://qikr.co/svngw
http://qikr.co/vwtz7
http://qikr.co/rkrsz
http://qikr.co/eyb76
Old 06-21-2011, 01:31 AM   #5 (permalink)
I think the burn is really bad. Even though you can find a used headlight to switch out the back cover (I doubt it can be done, but just try), you can't ensure the proper seal to prevent moisture coming in. If you want a proper installation of a bulb (good cut-off and beam pattern) and free of condense later, you should buy a new headlight.
It looks like the bulb caused this. What type of bulb is that? Did you properly install it?
Old 06-21-2011, 08:36 AM   #6 (permalink)
yep. looks like you need new headlight or projector if you know how to replace it.
let me know if you need progector or headlight, got some for sale.
For sale gen 6:
Old 06-21-2011, 09:18 AM   #7 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
^ it's not so hard. Just need to remove the front bumper to get access to all the screws and pop out the headlight unit.
workerant is online now   Reply With Quote
The Following User Says Thank You to workerant For This Useful Post:
Rheezie (06-21-2011)
Old 06-21-2011, 03:51 PM   #8 (permalink)
Yeah aftermarket bulb. I didnt install was previous owner. Was aware though. Gonna go new and get it over it.
Old 06-21-2011, 03:51 PM   #9 (permalink)
Thanks guys for all your help. New replacement seems to be the way to go.
