Please help 07 camry ABS, VSC, traction light are on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2011, 12:55 AM   #1 (permalink)
bawazir_chicago's Avatar
View bawazir_chicago's Photo Gallery
Unhappy Please help 07 camry ABS, VSC, traction light are on
Please help!
My 07 camry ABS, VSC, and traction lights are on, as the light comes ON I shut my car off Than it gose a way, but than after couple of miles comes back on.
Every time I brake my car pulls to the right and makes squeeek sound is that relevant to the light in my dash?..
My check engine light Dose NOT comes on so thank God of that
Pls help am in Kuwait and the dealer here would not take my car in since I shipped it from the U.S
Thanks
It's hard to be humble when you're from Chicago.
link:http://www.cardomain.com/ride/3820102
bawazir_chicago is offline   Reply With Quote
Old 06-24-2011, 03:04 AM   #2 (permalink)
Anyone pls help!
Old 06-24-2011, 08:29 AM   #3 (permalink)
11LE's Avatar
Gameroom cash: $243600
View 11LE's Photo Gallery
Do you have HID's installed?
If so, the placement of your ballasts are very important. If too close to the abs/trac control module or anything electrical, it could mess with the normal operation of the modules from interfering frequencies/waves and whatnot. I've seen cars of many makes have issues with their trac control/abs/esp etc all at once from improper HID ballast mounting.
Good luck!
Super White 2011 LE
|Debadged|-|4300k HID's|-|Tinted|-|Wheel Pkg|-|OEM Tip|-|Covered Squirrel Spotters|-|Yakima Rack System|-|Illuminated Cup Holders|
11LE is offline   Reply With Quote
Old 06-24-2011, 08:57 AM   #4 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
If it is pulling to one side, then the hydraulics aren't working correctly or the pads on one side are worn out. Pull the left wheel off and look at the rotor for scoring, at the pads for complete wear, and see if there are any hydraulic leaks in the hose. If that is OK, then the problem needs to go to the dealer because it is more likely in the proportioning valve next to the engine. There is a reason it is pulling. The lights are coming on because it is pulling to one side.
gdanaher is offline   Reply With Quote
The Following User Says Thank You to gdanaher For This Useful Post:
Donald E. George (06-24-2011)
Old 06-24-2011, 11:18 AM   #5 (permalink)
Gameroom cash: $202800
View Donald E. George's Photo Gallery
Right on gdanaher. Something is affecting the rotation of the right front wheel and the ABS system is detecting a brake lock-up. Could be calliper pins or pads as stated. You should be able to see something out of whack when you pull the wheel. Regards
Donald E. George is offline   Reply With Quote
Old 06-24-2011, 02:15 PM   #6 (permalink)
wow that is some good info will check the brakes, my brakes are bad, but just wondering why would the brake light comes on, why the trac or skid light come on???
Old 06-24-2011, 02:16 PM   #7 (permalink)
Good luck!
Yes i do and one of my HID is not working as well,,, will check on that as well,
and i have installed mouth mirrors signal mirrors,
