Well i tried to jb weld a piece of metal to cover my squirrel spotters, well NOW everytime i drive at night i notice my lights getting dimmer, then when i get out the housing is full of smoke!! I th8ink i may have givin myself a reason to do a retrofit!
~~~~~~~> BLACK 09 Camry SE V6 <~~~~~~~
- Debadged - Blacked out Logos - Heated Leather - 20% Tint -
- Resonator Delete - K&N Drop In - Blacked Out Lights -
- OEM All Weather Floor Mats -
What did you end up using to cover up the ss? I let my JB weld sit overnight and then some to ensure everything is well set. Sounds like something is melting. I wouldn't use your lights until you figure things out to prevent a fire.. D:
Super White 2011 LE
|Debadged|-|4300k HID's|-|Tinted|-|Wheel Pkg|-|OEM Tip|-|Covered Squirrel Spotters|-|Yakima Rack System|-|Illuminated Cup Holders|
its a piece of metal clamp used to hold the intake together on an aftermarket cai
was it painted?
paint mite burn.
I used unpainted alluminum in my MDX projerctors to make a shield. all good.
__________________ IndianaBorn gen7 LE. For sale gen 6: MdxTSXr black shrouds 5K retro OEM key with transmitter 2.4 transm.filter+gasket+WS. 2.4 K&N drop-in+cleaner and oil
Ok I took my lights out AGAIN to figure out the problem! Turned out to be the pieces of metal I used felloff the kb weld never welded for me! So what I did was dump out the piece of metal that was now loose in my projector and cleaned up the scraps as much as I could, I then took a scfewdri er and bent down the piece of metal above the bent down squirrel spotted so now there is no gap I turned on my heads for about 20 mundane NO SMOKE! Now I need to wait till it's dark to see how it turned out!
I also threw some silverstar ultras in my fogs and took the old fogs and put them in my heads, the old heads were shot because of the kb weld!
H9 produces about 2100 lumens, while H11 produces 1300 lumens. Their prices are not much different (probably the same; you can google it). An H9 bulb, of course, will have shorter life span than an H11 bulb.
