Camry 11: hot spot near transmission shifter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2011, 09:07 PM   #1 (permalink)
View jackb11's Photo Gallery
I have a two-month old 2011 Camry automatic transmission basic model. Just noticed a problem exactly the same as described in the following three links for older models, i.e., a hot spot on the console surface area between tranmission shifter and the little storage cube before the armrest. It's a very small, pretty much in the lower left corner, just below the P-R-N-4-D...lights.
http://www.toyotanation.com/forum/ar.../t-212129.html
http://www.toyotalexusforum.com/toyo...ssion-fix.html
Hot spot on center console?
Anyone has the same observation? Is this a problem or normal?
Nothing conclusive was found in the above three links. Any expert opinion on this? Thank you very much!
jackb11 is offline   Reply With Quote
Old 06-30-2011, 02:35 AM   #2 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $819821
iTrader Score: 16 reviews
View GT-R's Photo Gallery
Yeah my 09 has the same thing but no problem so far, I think it's normal.
GT-R is offline   Reply With Quote
Old 06-30-2011, 05:00 AM   #3 (permalink)
View Wundurra's Photo Gallery
I noticed the same thing on my 07 Camry... seemed to be the light under the panel to light up each of the transmission indicators
Wundurra is offline   Reply With Quote
Old 07-06-2011, 08:54 AM   #4 (permalink)
View Julie2010Camry's Photo Gallery
Hot Spot under Transmission Shifter
I have a 2010 Toyota Camry and I noticed a 2" in diameter "hot spot" about 1" down from the transmission shifter (right before the cup holder). Has anyone figured out why this is happening? It gets hot after about 15 minutes of driving.
Julie2010Camry is offline   Reply With Quote
Old 07-06-2011, 11:46 AM   #5 (permalink)
270hp = Happy Foot
Gameroom cash: $395545
View aznlunatic206's Photo Gallery
The reason why there is a hotspot is because of the small halogen bulb that lights up the shifter lights (P,R,N,ect.). I replaced mine with a white led so i dont have that problem.
2011 Camry SE V6 Fully Loaded w/o Navi
V-HIDS 5000k HID Kit Low Beam, 3000k Nokya Fogs
20% Aegis Tint, 50% Front Windshield
Tein Solara Springs on KYB GR2's
aznlunatic206 is offline   Reply With Quote
Old 07-06-2011, 11:48 AM   #6 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Were u driving with the lights on? I think it's that shifter light bulb heating up because it sits just below the shifter.
Old 01-14-2012, 12:44 AM   #7 (permalink)
View Parmar's Photo Gallery
2011 Camry Hybrid getting hot at the same place
I have 2011 Camry Hybrid and it is getting hot at the same place just behind the shifter. It is getting hot in day time as well when lights are not on. I did check other forums and found that in BMW E36 also get similar problem (http://forums.pelicanparts.com/101-p...tentially.html), reason here is rubber boot on shifter may have got torn out that allows enter engine hit. But this BMW E36 message was for 1997 year make car that was reported in 2008. Where my car is barely a year old car with 13k miles on it. So I doubt rubber boot may have torn out in my car. Not sure about halogen lamp, as it is getting hot in day time as well when lights are not on.
So, please post the solution if anyone have got it.
Thanks much.
Parmar is offline   Reply With Quote
Old 01-14-2012, 03:48 PM   #8 (permalink)
GeeEssVee's Avatar
View GeeEssVee's Photo Gallery
SOLUTION TO THIS PROBLEM: dont put your hand there when driving.
GeeEssVee is offline   Reply With Quote
Old 01-15-2012, 11:26 AM   #9 (permalink)
bleachigo's Avatar
Gameroom cash: $244505
View bleachigo's Photo Gallery
07 red XLE V6,SE grille,Megan coils,Nokya 7K Arctic White fogs,LED int.& ext.,pwrfolding,heated turn sgnl mirrors,5k HID,UR sb&rsb,LED door handles,25% tint,Sprtwing roof splr,JDM lic.plate hldr,JDM sidemarker,JDM mirror switch,AVS slim visors,ass shave,F5 CAI,cut shifter
bleachigo is offline   Reply With Quote
Tags
console, hot, transmission
