Originally Posted by jebra
I don't know anything about transmissions, so I will have to find someone to check the things you mentioned (linkages, etc.). I don't think the transmission fluid on this vehicle has ever been changed.
Am I correct in taking from your reply that you feel there is a decent chance that the entire transmission may not have to be changed out? Thanks again!
Trans oil isn't going to make a difference with the symptoms you describe.
As odds go, the likely scenarios:
- Debris in the shifter. You would notice this with shifter not going as far for 5th engagement.
- Bad/out of adjustment shift linkage. You'd generally notice slop and/or travel issues.
- Bad 5th gear shift fork. No external symptoms other than what you describe.
- Bad 5th gear gearset. Ditto 3.
For the last 2, cracking the case is required, which entails removing the trans. That's a fair piece of labor, and it's cost-effective to go through and freshen the synchros and replace the clutch 'while you are in there'. A replacement used tranny or a rebuilt unit may be cost-effective alternatives. Used trannies in good shape may be hard to come by, as the combo is fairly rare.
