2002 Camry LE Brake Fade
So I've been having some problems with the driver side front brake. I took the car in for a tire balance and rotation a few months ago. When I got it back, it had a vibration and I could smell the brake pad burning. At high speeds the steering wheel had a bad shake. Not sure if it's related to the balance/rotation, maybe just a coincidence.
I had the pads and rotors replaced. The problem was still there. The problem is very intermittent. Some days you'll get a vibration and other days you will feel the brakes fading as it takes a long time to stop and when you do, you smell the organic brake pad burning. I think the vibration was caused by the piston in the caliper sticking. It would unstick itself after it cooled. You would smell the organic brake pad burning as well when it was sticking.
Doing a little research, I thought the piston in the caliper might be sticking or maybe the brake line is going bad so I had those replaced Saturday. Took the car for a road trip today and towards the end of the 2.5 hour road trip, I could feel the brakes fading again.
I plan on replacing the pads anyways due to the squeaking. They are Advance Semi Metallic pads. I plan on going back to Autozone Ceramic ones as I've had good luck with them in the past.
Seeing as I've replaced the pads, rotors, calipers and line, what else could be causing the brake fade? Only time will tell if replacing the caliper/line will have stopped the vibration.
Thoughts? What else should I be looking at? Master/Slave cylinder look good, no leaks and the problem is isolated to the driver side brake.
