Howdy.
Toyota does not sell bolts or nuts for air box. you need to buy air box assembly.
and box ain't cheap.
you not the first and I'm sure not the last person having this problem.
go to hardware store and get 10mm machine bolt and matching square nut (get couple different sizes, I don’t remember which one fits).
remove your air box and install nut where original nut was.
Trim nut or box plastic a bit to make it fit.
You need some glue to attach it to the box.
I used two tiny nails, drove them through the box plastic wall under the nut to make it stay in place.
install air box base and top cover.
drive bolt with washer into nut.
That’s it.
screw for bumper-call any toyota store.they usually $1.50 a pc.
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
