Sticky Brake Pedal
This is my 2009 XLE I4 with less than 20k miles. It has happened twice in the past 7 days. When I came off a highway and approached a stop sign, I put my foot on the brake pedal to slow down and then took my foot off the pedal once it reached the desired speed. The brake pedal did not come up as my foot lifted up (normally, when you lift your right foot off the pedal, you feel the pedal come up with your foot while maintaining contact with your foot). But as my foot lifted up, I could tell the pedal lost contact with my foot--it stayed depressed. Other than that, the car is running fine. Full brake fluid in master cylinder. No CEL. Coincidentally, both times happened at the same stop sign. The car is out of warranty and I appreciate your input.
