Tein Lowering Springs Noise Problem 11 Camry SE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2011, 12:29 PM   #1 (permalink)
View kobe4life323's Photo Gallery
Gen6 Tein Lowering Springs Noise Problem 11 Camry SE
Ok so its been about 2 weeks now i have had my Tein Lowering Springs on my car with My 20 Inch Wheels 20x8.5 +32 just for reference and I seem to be having a little problem with it nothing major but just really annoying i dont know if any of you fellow toyotanation members got this problem. everytime I turn out of a driveway or just turn into a street or anything that has to do with the car flexing I hear something popping on top of the roof of my car. as if the hole top of my car is flexing and making a weird creaking/popping noise. LOL I understand the springs are stiffer then the OEM and i understand that is probably the chassis or the frame just flexing but hearing a weird sound on top of the roof by the sunroof area is weird idk its my first so if any of you have that same problem or if its normal just let me know. I would appreciate the help.
kobe4life323 is offline   Reply With Quote
Old 07-08-2011, 01:14 PM   #2 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $819821
iTrader Score: 16 reviews
View GT-R's Photo Gallery
I thought your car got totaled by the dealer?
GT-R is offline   Reply With Quote
Old 07-08-2011, 01:22 PM   #3 (permalink)
I Have A 2011 LE And A 2011 SE the LE was purchased in SEP 2010 and the SE was purchased in FEB 2011 lol sorry for confusing u GT-R
Old 07-08-2011, 01:49 PM   #4 (permalink)
Gameroom cash: $195250
View ImJustMe55's Photo Gallery
The creaking/popping is probably the springs spinning/rotating when you turn the wheel. My k-Sport coilovers did the same thing until i ordered their anti-squeak kit, which was just a plastic washer sandwiched between 2 metal washers, but it worked. Later I found out about thrust bearings that help with that same problem. I've never tried them, but I would think they would do a better job than what I have. Here's a link so you can see what I'm talking about:
http://www.summitracing.com/search/D...s/?Ns=Rank|Asc
I hope that helps.
It's good to go fast, but even better to be able to stop!!
2007 V6 Camry SE: TRD Air Filter, Power Slot Rotors, Hawk PC pads, Techna-Fit Braided Steel Brake Lines
ImJustMe55 is offline   Reply With Quote
Old 07-08-2011, 01:53 PM   #5 (permalink)
I hope that helps.
ok cool so are these things universal or i have to go with a ceratin spec. basically what im trying to say is what would you recommend with my tein dress up masters. lol idk if taking apart the hole thing all over again is worth that little popping sound
Old 07-08-2011, 02:02 PM   #6 (permalink)
They are universal. Just make sure you get the same diameter as your springs. You should use 2 washers and 1 bearing on the top and bottom of each spring. Unfortunately the only way to put them in is to take them all the way apart. I didn't want to take my whole setup apart either so I waited until my shocks blew and I installed the kit with my replacement shocks. The popping sound is gone on my car, but I wonder about how long it will last since K-Sports uses a plastic washer instead of a bearing.
Old 07-08-2011, 02:42 PM   #7 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Oh I see.
Well as for the roof popping, it's the welding, mine does that too.
Old 07-08-2011, 05:07 PM   #8 (permalink)
View deuce106's Photo Gallery
its your sun roof rails ...take it to the dealer they will fix it
deuce106 is offline   Reply With Quote
Old 07-08-2011, 05:19 PM   #9 (permalink)
View eddiefromcali's Photo Gallery
wife's 07 LE on TRD springs does the same but it comes from the tire area...never bothered finding out exactly where its coming from though
07 Camry LE V6 - TRD drop, Fujita CAI, IS350 Wheels, SE Grille
eddiefromcali is offline   Reply With Quote
Old 07-08-2011, 09:03 PM   #10 (permalink)
I Eat Accords! W_(^_^)_W
my.rims.are.stock's Avatar
Gameroom cash: $114800
View my.rims.are.stock's Photo Gallery
Mine used to that when I first got the Teins, especially when backing up and turning down an incline. It will still do it if I jack the car up and then put it down. I think it is the car settling on the springs. Especially if the springs are new. Another thing is that the car does flex when turning, so keep that in mind.
my.rims.are.stock is offline   Reply With Quote
