Bank 1 vs Bank 2 Air Fuel Sensor - 2002 Camy V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-09-2011, 01:03 AM   #1 (permalink)
View I.B.'s Photo Gallery
Gen5 Bank 1 vs Bank 2 Air Fuel Sensor - 2002 Camy V6
Hi all;
For a 2002 Camry V6, I was looking to replace Air Fuel Sensor (Bank 1 Sensor 1). Unfortunately, I made a mistake when ordering the part and ordered Bank 2 Sensor 1 instead. The parts look identical, but they have two different Toyota part numbers which are:
89467–33060 for Bank 1 Sensor 1 (The one needed)
89467–33050 for Bank 2 Sensor 1 (The one ordered by mistake)
My question is, are the two sensors interchangeable, or are there some specification differences?
Thanks in advance for your help.
2002 Camry SE V6
I.B. is offline   Reply With Quote
Old 07-09-2011, 07:59 AM   #2 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
Originally Posted by I.B. View Post
Hi all;
my guess is the wire may have different length, i've swap sensors between bank 1 and bank2 on my rx300, and no CEL
also, instead of toyota oem sensor, i've tested denso A/F oem style from rockauto or amazon, seem to be identical to toyota a/F sensor at 1/2 price.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
The Following User Says Thank You to bronzemaxell For This Useful Post:
I.B. (07-11-2011)
Old 07-11-2011, 08:49 PM   #3 (permalink)
Thanks a lot bronzemaxell. I did get the sensor installed today. Fits perfectly, and the corresponding DTC Code (P1130) is gone now. You were right, the length of the wires is different between the two. The replacement sensor had a longer wire.
2002 Camry SE V6
Tags
2002 camry, 89467–33050, 89467–33060, air fuel sensor, interchangable parts
