Gear Light On Instrument Cluster Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-09-2011, 09:12 PM   #1 (permalink)
ed310's Avatar
View ed310's Photo Gallery
Gen5 Gear Light On Instrument Cluster Issue
On a 2005 Camry LE with A/T, the gear light on the instrument cluster started acting up. On Parking, no problem. On Reverse, the "R" is lighted up and the "N" also tends to light up, it flickers every now and then, sometimes even completely lighted up. On Neutral, no problem. On Drive, no problem. When shifting down into 3 and 2 the "N" light lights up momentarily during the shift.
Has anyone had this problem before? Any idea on what the problem can be? Car is still under warranty. I took it to the dealer just to ask and they said that since its still under warranty, they would not charge if whatever is wrong is covered under warranty. If whatever is wrong is not covered under warranty, I would get charged $50 for the inspection.
Attached are pics and video
Pic: http://i560.photobucket.com/albums/s...310/Lighta.jpg
Pic:http://i560.photobucket.com/albums/s...310/Lightb.jpg
Video: http://s560.photobucket.com/albums/s...ftinglight.mp4
ed310 is offline   Reply With Quote
Old 07-09-2011, 09:22 PM   #2 (permalink)
Gameroom cash: $245200
View fatngs's Photo Gallery
hmm tht is kinda wierd.... does it do that no matter the brightness of the cluster??
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
Old 07-09-2011, 09:41 PM   #3 (permalink)
ed310's Avatar
the brightness of the cluster does not make a difference, i tried it from 0 light to full brightness and it still does the same thing
Old 07-09-2011, 09:46 PM   #4 (permalink)
well it could be a number of things.... loose wire, bad connection, damaged circuit board, damaged LED....... honestly its something i would just live with because u can try soldering in a new LED but u havta tear appart the cluster or even if u replaced the whole thing u havta go the the dealer to have it reprogramed which is not cheap
Old 07-11-2011, 11:58 AM   #5 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
Try to check the performance of the charging system. Autozone or Kragen do it for free.
Good luck,
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Old 07-13-2011, 09:06 PM   #6 (permalink)
ed310's Avatar
i ended up taking the car to the dealer bc it would stall when shifting into gear and check engine light came on
turns out it was the neutral safety switch that was faulty. it fixed the problem with the stalling and the cluster gear light
