Getting resonance around 200-2500 RPMs as you accelerate. Exhaust is new as of Saturday and so it is quieting down a bit as carbon starts to coat the inside. Hopefully, this will continue. I love the sound as you start it up, the idle...generally everything but that particular range noted above.
After searching the forum I have found that to get rid of the noise:
- You cannot wrap the pipes with header tape;
- You cannot Dynamat the Bejesus out of the trunk area;
- You cannot spray foam crap up under car;
-You cannot use that smelly Dynamat substitute from Lowes or Home Depot;
- You cannot get rid of the noise.
So my questions are:
1) Has anybody tried Dynapad (not Dynamat) in the trunk?
2) If I were to take stainless steel hose clamps (as you use for radiator hoses) and placed a couple of them along the length of the straight back pipe and snugged them tight, would that break up the resonance wave?
Thanks.
