Wheel Shaking Problems (Warranty Issues) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2011, 11:15 PM   #1 (permalink)
View kobe4life323's Photo Gallery
Gen6 Wheel Shaking Problems (Warranty Issues)
ok so idk if any of you read one of my earlier threads but I put my whole car back to stock to take it back to the dealership because my rotor was grinding against the caliper. dealer said it was debris stuck in my rotor that was causing the rotor to rub against the caliper and that they cleaned it. after they cleaned it i noticed my steering wheel would start shaking now from 60-80 MPH. IDK if this had anything to do with the rotor and caliper because i know the caliper was messed up pretty bad and the rotor was scratched up pretty bad but they didnt want to fix it because i was going thru some other problems with them regarding them crashing my other car while in service. back to the main part i took the car in for steering wheel shaking problem they said it was one of my wheels that were way off balance got the car back and its still shaking from 60-80 and 110-120 MPH. The funniest part was when i told that to my service advisor and the tech standing next to him all of you guys should have been there to see their priceless looks on their faces when i said 120 MPH. I WAS SERIOUS.. anyways what do you guys think this weird shaking is???
kobe4life323 is offline   Reply With Quote
Old 07-18-2011, 12:24 AM   #2 (permalink)
ilikecamrys
Cking's Avatar
Gameroom cash: $532185
iTrader Score: 17 reviews
View Cking's Photo Gallery
sounds like your rotors are warped. its covered under warranty. I got it fixed for free at the dealer.
2k8 V6 Camry SE\\55w6000kHID||3000kfogs||Work Emotion CR-ULTIMATES
||BuddyClub Coilovers||SPC Camber Bolts||TRD Dual Catback Exhaust
||Megan FrontTowerStrutBar||StopTech Slotted Rotors||PosiQuiet Pads
||Fujita ColdAirIntake||My thread!||TN lanyards!||
Cking is offline   Reply With Quote
Old 07-18-2011, 12:31 AM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
120? Please do take care of yourself.
60-80 could be a wheel balance issue. Or maybe a bad tire? Try rotating them around and see if the problem moves. Did they use Hunter Road Force balancing machine?
But if it's under warranty it should be fixed for free.
Old 07-18-2011, 05:15 AM   #4 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
What John said. Most likely a re-balancing is needed. This recently happened with my '08 after getting the tires rotated. After having the wheels re-balanced, the car drives as smooth as it should.
'08 Camry LE 5-speed. Traded for an '04 Mustang GT.
87Camry5Speed is offline   Reply With Quote
