2007 SE Factory Nav JBL Bluetooth update? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2011, 02:31 PM   #1 (permalink)
View CtotheP's Photo Gallery
I'm having issues w/ others hearing me on the other end while using bluetooth. I have a Blackberry Bold 9700 and have had no issues pairing it or with volume. The reception for the folks on the other end of the line fades in and out. To verify it's not my carrier, I have taken it off bluetooth and used both the handset or wired headset in the same areas multiple times and they can hear me crystal clear.
Anyone know if there is a system/firmware update for the Bluetooth? I've got the latest Nav v.10
CtotheP is offline   Reply With Quote
Old 07-21-2011, 04:12 PM   #2 (permalink)
07 Camry XLE
View Vikja Manni's Photo Gallery
I'm interested in this answer too. I have similar problems.
Vikja Manni is offline   Reply With Quote
Old 07-21-2011, 05:02 PM   #3 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
I could be wrong, but as far as I know, there's no "update" to the Bluetooth system. If you want a newer, updated system, I believe you have to purchase a newer car. In my 2011 SE, the person on the other end can usually hear me just fine, unless the climate control is on high, then it becomes difficult to decipher what's being said.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 07-21-2011, 08:02 PM   #4 (permalink)
ScooterL's Avatar
View ScooterL's Photo Gallery
There is a TSB with instructions on how to adjust the sensitivity of the microphone. I think this helps most with this issue. I'm not sure how cooperative the dealers are with this.
Sent from my Autoguide iPhone app
ScooterL is offline   Reply With Quote
Old 07-22-2011, 09:00 AM   #5 (permalink)
Need For Speed
^I have heard of this solution before. From what I've been told, it helps somewhat but it's still not quite up to par with the newer systems. But who knows? It may be enough to suit your needs, OP.
Old 07-26-2011, 08:52 AM   #6 (permalink)
I'm torn as to whether or not the volume sensitivity could be the root problem as the actual bluetooth connections seems to be weaker at times than others. I'll keep digging and see if I can find anything else.
Old 07-26-2011, 01:59 PM   #7 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
There's a tsb for replacement of the head unit. Had it done on my 2010 and it solved my issue.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
